sfryman
- Dec 11, 2016
My current home server is 7 years old, and was old technology even when I bought it. I use an Intel SS4200-E running OpenMediaVault. I've upgraded it over the years, but it's no longer able to keep up with our needs. It's got an Intel Core2 Duo E4700 @ 2.6ghz with only 2GB RAM (max possible). The biggest issue is that it can only take max 2GB capacity drives, and the 4x2GB drives are now full. Also, the system is not able to keep up with plex transcoding when I have more than a couple users, or depending on the source file it struggles to keep up with a single 1080p stream (although it does better than I initially expected).
The replacement server will have 5 adults and 3 children as primary users, with the potential for additional remote users of plex as well. I am looking at starting with 16 or 18TB of storage. The system must be capable of at least 3 simultaneous plex streams. It will store my media library, home movies, photos, personal and work files. It will also serve as primary backup for all the house PCs: currently 2 desktops & 3 laptops. Also everyone has their own tablet.
My budget is ~$2k. I'm disappointed with the cost vs. performance of brand new hardware so have been looking primarily at used servers. I strongly am considered the Dell C2100 based on the linked thread but it seems a tad out-of-date... I came across a local deal on a used server that I'd like some input on:
Case:
Supermicro SC825TQ-R740LPB (8 Drive bays, 2x 740W platinum power supplies)
MB:
Supermicro X9DR3-LN4F+
CPUs:
(Dual) Intel Xeon E5-2690 2.9Ghz Eight Core CPU - https://www.cpubenchmark.net/cpu.php?cpu=Intel+Xeon+E5-2690+@+2.90GHz&id=1223&cpuCount=2
RAM: 64GB RAM (8x 8GB) - I don't know the manufacturer, it's already installed and tested (per seller)
RAID Card:
LSI 9260-8i - I think this could be a problem since it doesn't have a passthrough option for ZFS. But I think I could re-sell this one and use the money to buy a ZFS-compatible model?
NIC:
Installed Intel X520-DA2 Dual 10GB SFP+ NIC (no optics)
4x Gigabit Ethernet LAN ports; Intel® i350 Quad port GbE controller
I can get the above setup for $1250 (used) locally. Perhaps a tad overkill, but the price seems pretty good in my limited experience.
Seems to be the same as a bare-bones system still being sold on newegg: http://www.newegg.com/Product/Produ...&cm_re=SYS-6027R-3RF4+-_-16-101-693-_-Product
It's used but comes with two pretty decent processors.
For the hard drives I was thinking about either 4x4TB or 6x3TB drives. I was going to go with Seagate NAS or WD Red drives.
But someone recommended enterprise SAS drives, which are a little more expensive: https://www.amazon.com/dp/B00A45JFJS/?tag=ozlp-20
I don't know much about SAS, but seems like it's better for multiple simultaneous users. I have noticed that my current home server can maintain 100MB/sec transfer with a single user, but when other users come on it drops ALOT.
Advice, suggestions, comments? Please and Thank you!
Case:
MB:
CPUs:
RAID Card:
NIC:
