For let me start off that I'm a complete noob when it comes to setting up a RAID. I have never done one before, but I have been reading quite a bit about it, which has ultimately led me to this site. I am now planning to build a RAID server, and had some questions about it. Mainly to dispel the conflicting stuff I've read online.
The intention is to build a RAID 5 (5x or 6x 2TB HDs) that will be used as a media server for my music, pictures, and videos. I would like to stream 1080p video from this RAID'd media server. Media server should be Windows friendly.
1. I like the idea of RAID 5 in that you get a fault tolerance while having a lot of storage space. However, I've read that RAID 5 is risky in that sense that corruption can occur and that recoveries often fail. They say that restoring with a RAID 5 can be very difficult, and can fail. Despite having no more than 1 HD fail, it is very possible that the RAID won't be re-buildable. Are these statements true?
2. In the event that you have a 1x HD failure in a RAID 5, how easy is it to rebuild the RAID with FreeNAS? Is it just a matter of shutting down, placing in a new HD, and starting back up?
3. Once the RAID 5 is up and running, how hard is it to expand it? Let's say I fill up the space, and want to expand it. Can I just replace the HDs one by one with larger HDs, and let the RAID 5 rebuild itself each time until I've put in a whole new set of HDs?
4. Having a software RAID 5 is very slow. However, I had trouble determining what "slow" is, and if it matters for my case. I'm not using it for any kind of industrial purpose. It's mainly for home use. I want to store large video files (~15GB) 1080p files. Ideally, I would like to be able to write and read at the same time, with read speeds sufficient for streaming on a home network (my LAN speeds are sufficient as I currently do this with a single HD on a 2.8GHz P4 w/ 2GB ram)
5. What kind of Ram/CPU power would be sufficient for my home use, media needs? Like an Intel cerelon, or an Intel quad-core i7? I was thinking along the lines of a dual core i3 or potentially a i5. Quad core or Dual core? 8GB ram sufficient? or need 16gb preferably?
6. I've read that ZTS is very good in preventing corruption and for monitoring the RAID 5. However, major downfall is that it "slows" the system. Again, what does "slow" mean? Would it be enough to meet my purpose? If so, what kind of hardware would I need?
Thanks a lot!
Thanks a lot!
