Pkg Not Updating
Andre Clarke
Stopping radarr.
root@Radarr:~ # pkg update
Updating FreeBSD repository catalogue...
pkg: An error occured while fetching package
repository FreeBSD has no meta file, using default settings
Unable to update repository FreeBSD
Error updating repositories!
this is happening for all jails.... dns is set
What version of FreeBSD are these jails based on? Maybe you need to upgrade the jails?
Patrick M. Hausen
12.2 is EOL since January 2022. You need to run a supported release to install packages.
The current supported FreeBSD release for jails on TrueNAS CORE is 13.3. You need to run TN CORE 13.0 for that.
Andre Clarke
Thanks for replying…..Ok..I totally forgot how to upgrade the jails, is there a tread that can guide me how to
Patrick M. Hausen
iocage fetch -r 13.3-RELEASE
iocage upgrade -r 13.3-RELEASE <jailname>
For a bulk upgrade of all jails:
iocage list -h | awk '{ printf "iocage upgrade -r 13.3-RELEASE %s\n", $2 }' | sh
...or you can upgrade jails through the GUI.
That works for "patch level" updates, such as -p3, -p4, -p5, etc. I've never seen anywhere in the GUI that lets you fetch a new FreeBSD release (e.g, 13.1, 13.2, 13.3, 14.0, etc) and upgrade the jail's release, for already existing jails.
Patrick M. Hausen
I could have sworn it was in there, but I sure don't see it now.
Andre Clarke
Keep getting this error after i upgraded my radarr jail, it wont start........ any help
freenas kernel: pid 86315 (daemon), jid 8, uid 816: exited on signal 12
Patrick M. Hausen
iocage stop <jailname>
iocage rollback -n ioc_upgrade_2024-03-07 <jailname>
iocage start <jailname>
That rolls back your jail to the state before the upgrade. You can then repeat the upgrade procedure but with 13.2 instead of 13.3.
Andre Clarke
i get this when im trying to rollback
tank/iocage/jails/Radarr@ioc_upgrade_2024-03-07 does not exist
Patrick M. Hausen
Then list all your snapshots for the Radarr jail - there must be one created by iocage when you upgraded.
Andre Clarke
@Andre Clarke - don't upgrade all the way to 13.3 now. Go to 13.2 instead which will still be supported for a couple of weeks.
If you already upgraded and find that at least for some jails applications don't start, please see this post for an explanation: https://www.truenas.com/community/t...s-core-jails-to-freebsd-13-3-just-yet.117018/
I can assist rolling back to your previous 12.2 version and redoing the upgrade to 13.2 if you need help.
Kind regards,
Patrick
Saw this late
Patrick M. Hausen
Andre Clarke
thats weird it didnt create a snapshot of any of the jails i updated
thats ok, i appreciatethe help
last snap was 2022
Andre Clarke
can i just install 13.2 over it?, there snaps of the jails install, but in jails it shows 13.3
Patrick M. Hausen
If you are more interested in a quick fix than a long term solution and you can wait for the next TrueNAS release for that, you could try from the TrueNAS host:
cd /mnt/tank/iocage/jails/Radarr/root/usr/sbin
mv daemon daemon.bak
cp /usr/sbin/daemon .
iocage restart Radarr
HTH,
Patrick
