itsryan
- Jan 11, 2017
Over the last few months I have been noticing a problem with some jails. Randomly jails will stop connecting to pkg.freebsd.org only when a command from PKG is used. I am not able to run ANY PKG command or i will get the errors.
This started on a few jails but its growing to other ones. now it has reached my plex server and I can no longer do updates. but the plex and websites are still accessible for outside/inside the network. its only updates.
Other jails will sometimes give me this error
if i try and update in debug i get this error
I know the plex jail is giving me a different error, but I believe they are both caused by something.
I have gone through my ubiquity firewall to see if anything in there might be blocking it but no luck.
Can anyone point me in a direction that will hopefully solve this problem.
root@plex:~ # pkg
The package management tool is not yet installed on your system.
Do you want to fetch and install it now? [y/N]: y
Bootstrapping pkg from pkg+http://pkg.FreeBSD.org/FreeBSD:12:amd64/latest, please wait...
pkg: Error fetching http://pkg.FreeBSD.org/FreeBSD:12:amd64/latest/Latest/pkg.txz: Not Found
A pre-built version of pkg could not be found for your system.
Consider changing PACKAGESITE or installing it from ports: 'ports-mgmt/pkg'.
I have looked all over for a solution to this and it keeps coming up as a DNS problem, so I have played around with /etc/resolv.conf making sure I have 3 nameservers 192.168.1.1, 1.1.1.1, 8.8.8.8.root@plex:~ # ping pkg.freebsd.org
PING pkgmir.geo.freebsd.org (96.47.72.71): 56 data bytes
64 bytes from EDIT for privacy: icmp_seq=0 ttl=50 time=32.136 ms
64 bytes from EDIT for privacy: icmp_seq=1 ttl=50 time=31.410 ms
^C
--- pkgmir.geo.freebsd.org ping statistics ---
2 packets transmitted, 2 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 31.410/31.773/32.136/0.363 ms
root@plex:~ # pkg-static update
pkg-static: Warning: Major OS version upgrade detected. Running "pkg bootstrap -f" recommended
No active remote repositories configured.
root@plex:~ # pkg bootstrap -f
root@prowlarr:~ # pkg update
Updating FreeBSD repository catalogue...
pkg: An error occured while fetching package
repository FreeBSD has no meta file, using default settings
Unable to update repository FreeBSD
Error updating repositories!
root@prowlarr:~ # pkg -d update
DBG(1)[40611]> pkg initialized
DBG(1)[40611]> PkgRepo: verifying update for FreeBSD
DBG(1)[40611]> PkgRepo: need forced update of FreeBSD
DBG(1)[40611]> Pkgrepo, begin update of '/var/db/pkg/repo-FreeBSD.sqlite'
DBG(1)[40611]> Request to fetch http://pkg.FreeBSD.org/FreeBSD:12:amd64/latest/meta.conf
DBG(1)[40611]> curl_open
DBG(1)[40611]> Fetch: fetcher used: http
DBG(1)[40611]> curl> fetching http://pkg.FreeBSD.org/FreeBSD:12:amd64/latest/meta.conf
DBG(1)[40611]> CURL> attempting to fetch from , left retry 3
* Couldn't find host pkgmir.geo.freebsd.org in the .netrc file; using defaults
* Trying 96.47.72.71:80...
* Connected to pkgmir.geo.freebsd.org (96.47.72.71) port 80
> GET /FreeBSD:12:amd64/latest/meta.conf HTTP/1.1
Host: pkgmir.geo.freebsd.org
Accept: */*
If-Modified-Since: Thu, 01 Jan 1970 00:00:00 GMT
< HTTP/1.1 404 Not Found
* Failed writing header
* Closing connection
DBG(1)[40611]> CURL> attempting to fetch from , left retry 2
* Couldn't find host pkg0.fmt.freebsd.org in the .netrc file; using defaults
* Trying 192.158.248.8:80...
* Connected to pkg0.fmt.freebsd.org (192.158.248.8) port 80
Host: pkg0.fmt.freebsd.org
Accept: */*
DBG(1)[40611]> CURL> attempting to fetch from , left retry 1
* Couldn't find host pkg0.fra.freebsd.org in the .netrc file; using defaults
* Trying 147.28.184.43:80...
* Connected to pkg0.fra.freebsd.org (147.28.184.43) port 80
Host: pkg0.fra.freebsd.org
Accept: */*
DBG(1)[40611]> Request to fetch http://pkg.FreeBSD.org/FreeBSD:12:amd64/latest/meta.txz
DBG(1)[40611]> curl> fetching http://pkg.FreeBSD.org/FreeBSD:12:amd64/latest/meta.txz
* Hostname pkgmir.geo.freebsd.org was found in DNS cache
> GET /FreeBSD:12:amd64/latest/meta.txz HTTP/1.1
Accept: */*
* Hostname pkg0.fmt.freebsd.org was found in DNS cache
Accept: */*
* Hostname pkg0.fra.freebsd.org was found in DNS cache
Accept: */*
DBG(1)[40611]> Request to fetch http://pkg.FreeBSD.org/FreeBSD:12:amd64/latest/packagesite.pkg
DBG(1)[40611]> curl> fetching http://pkg.FreeBSD.org/FreeBSD:12:amd64/latest/packagesite.pkg
> GET /FreeBSD:12:amd64/latest/packagesite.pkg HTTP/1.1
Accept: */*
Accept: */*
Accept: */*
DBG(1)[40611]> Request to fetch http://pkg.FreeBSD.org/FreeBSD:12:amd64/latest/packagesite.txz
DBG(1)[40611]> curl> fetching http://pkg.FreeBSD.org/FreeBSD:12:amd64/latest/packagesite.txz
> GET /FreeBSD:12:amd64/latest/packagesite.txz HTTP/1.1
Accept: */*
Accept: */*
Accept: */*
