pkg not installed in Jail after upgrade from 12.2 to 13.0
cooter
I just upgraded Truenas to 13.1. After doing so I ran the iocage upgrade for all my jails. All worked well except my Plex jail. Plex is up and running, but I can't update any pkgs.
Here is the errors I get, seems to be an issue with certificates, but I am not sure how to resolve:
root@plexmediaserver-plexpass:~ # pkg update
The package management tool is not yet installed on your system.
Do you want to fetch and install it now? [y/N]: y
Bootstrapping pkg from http://pkg.FreeBSD.org/FreeBSD:13:amd64/latest, please wait...
pkg: Error loading revoked certificates
And when I try to use PMS Updater:
root@plexmediaserver-plexpass:~ # ./PMS_Updater.sh -vv -a
Using URL https://plex.tv/api/downloads/5.json
Searching https://plex.tv/api/downloads/5.json for the FreeBSD download URL .....Certificate verification failed for /C=US/O=DigiCert Inc/CN=DigiCert TLS RSA SHA256 2020 CA1
34374492160:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:/usr/src/crypto/openssl/ssl/statem/statem_clnt.c:1915:
fetch: https://plex.tv/api/downloads/5.json?channel=plexpass&X-Plex-Token=XXXXXXXXXXXXXXXXXXXX: Authentication error
  File "<string>", line 1, in <module>
  File "/usr/local/share/plexmediaserver-plexpass/Resources/Python/python27.zip/json/__init__.py", line 291, in load
  File "/usr/local/share/plexmediaserver-plexpass/Resources/Python/python27.zip/json/__init__.py", line 339, in loads
  File "/usr/local/share/plexmediaserver-plexpass/Resources/Python/python27.zip/json/decoder.py", line 364, in decode
  File "/usr/local/share/plexmediaserver-plexpass/Resources/Python/python27.zip/json/decoder.py", line 382, in raw_decode
ValueError: No JSON object could be decoded
Could not find a FreeBSD download link on page https://plex.tv/api/downloads/5.json?channel=plexpass&X-Plex-Token=XXXXXXXXXXXXXXXXXXXX
Any thoughts on how to fix?
Can you try in the jail,
pkg bootstrap -f
Followed by,
pkg update
Also try restarting the jail before and after doing the above.
cooter
I restarted the jail multiple times as you mentioned, here is result:
root@plexmediaserver-plexpass:~ # pkg bootstrap -f
This one is out of my wheelhouse.
Someone more well versed with FreeBSD might know how to refresh/update the reference to revoked certificates.
Alecmascot
Is the clock set correctly ?
Samuel Tai
In the Plex jail, does the /usr/share/keys/pkg/revoked directory exist?
Samuel Tai
Do you have a file in /usr/share/keys/pkg/trusted, named pkg.freebsd.org.2013102301, with contents:
# $FreeBSD$
function: "sha256"
fingerprint: "b0170035af3acc5f3f3ae1859dc717101b4e6c1d0a794ad554928ca0cbb2f438"
and permissions
-rw-r--r-- 1 root wheel 112 May 12 04:29 pkg.freebsd.org.2013102301
cooter
# $FreeBSD$
function: "sha256"
and permissions
root@plexmediaserver-plexpass:/usr/share/keys/pkg/trusted # ls
# $FreeBSD$
function: "sha256"
file "pkg.freebsd.org.2013102301", 4 lines, read only
root@plexmediaserver-plexpass:/usr/share/keys/pkg/trusted # ls -l
total 7
-rw-r--r--  1 root  wheel  112 Apr  9  2021 pkg.freebsd.org.2013102301
Patrick M. Hausen
What's the date and time of your system?
Samuel Tai
Something's gone corrupt in that jail. Try recreating it from scratch.
adrianwi
Does the jail have internet access? Has the update changed some network/DNS settings?
adrianwi
I think I'd probably rebuild it, and Plex shouldn't be too difficult to do. You should be able to copy across the plex user files too, or even better, move them to a dataset outside the jail and mount them back in.
cooter
I ended up rebuilding the jail which resolved the issue. One question I run into with my last jail and this new jail is when I run:
service plexmediaserver_plexpass status
I get:
root@plex:~ # service plexmediaserver_plexpass status
plexmediaserver_plexpass is not running.
But Plex is up and running. When I list services, this is the list of services the name is "plexmediaserver_plexpass". I can start and stop the service, but the status does not display properly. Thoughts on that one?
One thing I did when rebuilding it, was a backed up and restored my "Plex Media Server" directory/database. Not sure if that could impact this.
