First of all: Hi to everyone, I'm new :)
I'm currently looking for the best software RAID solution for my 3x 6TB WD RED.
I already tested XPEnology and Windows Server (Diskmgmgt RAID 5 and Storage Spaces).
Today I set up a Freenas 11.0-U2 VM on my ESXi 6.5 server and did some drive failure simulations with VMDKs. (3x 8GB; RAIDZ)
I noticed, when I detach one of the drives from the VM, it's state changes to 'REMOVED' or 'UNAVAIL'. I haven't found a way to bring it back online after reattaching it to the VM, though.
The only thing I can do is replacing it, which means the drive is being wiped and rebuilt, even though the data on it is completely fine, right?
Is there actually no other way? This would be kind of worrying.
E.g Windows would notice that I reattached one of the pool drives and set it back online. Even if I removed 2 of 3 drives.
I tried the following commands to get it back online:
I hope someone can help me here.
Thanks!
Skunky
root@freenas:~ # zpool status test
pool: test
state: DEGRADED
status: One or more devices could not be opened. Sufficient replicas exist for
the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
see: http://illumos.org/msg/ZFS-8000-2Q
scan: none requested
NAME STATE READ WRITE CKSUM
test DEGRADED 0 0 0
raidz1-0 DEGRADED 0 0 0
2398268917499464536 UNAVAIL 0 0 0 was /dev/gptid/966cf301-7c64-11e7-91af-000c295e13ce.eli
gptid/96a1f57a-7c64-11e7-91af-000c295e13ce.eli ONLINE 0 0 0
gptid/96d74475-7c64-11e7-91af-000c295e13ce.eli ONLINE 0 0 0
errors: No known data errors
root@freenas:~ # zpool clear test 2398268917499464536
root@freenas:~ # zpool online test 2398268917499464536
warning: device '2398268917499464536' onlined, but remains in faulted state
use 'zpool replace' to replace devices that are no longer present
root@freenas:~ # fmadm repaired zfs://pool=name/vdev=guid (obviously not a Freenas command)
Thanks!
Skunky
