Photogrammetry processing through Freenas
Ihluvathar
Hello community !
I'm new into freenas and i build a system to store and process my photogrammetry workflows using freenas storage, and i'm having some network issues, it seems that the network have some glitches interrupting my workflow and the result is thak some of the files created are corrupted. i'm using metashape and i have a freenas of 40tb in with a AMD Ryzen 3 3200G with Radeon Vega Graphics with 8gb of ram (info on the dashboard : 5.9 gb installed) 4 disks of 10 tb in RAIDZ1.
I would like to correct those glitches, any ideas to help ?
Thanks a lot !
Fredda
Please give more information of your used hardware. Please also klick on that big read link "Forum Rules" in the middle on top of this thread.
It explains what information a post should include.
Your network problems might likely be caused by suboptimal hardware (realtek NIC?). Also 8GB is the minimum memory sizes for FreeNAS.
Increase your RAM or try to reduce the RAM reserved for your emedded GPU to a minimum.
Ihluvathar
I'm sorry here are some more informations :
BIOS Information
Vendor: American Megatrends Inc.
Version: F50
Release Date: 11/27/2019
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 16 MB
Characteristics:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 5.14
System Information
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: B450 AORUS M
Handle 0x0012, DMI type 17, 84 bytes
Memory Device
Array Handle: 0x0009
Error Information Handle: 0x0011
Total Width: 64 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM 1
Bank Locator: P0 CHANNEL A
Type: DDR4
Type Detail: Synchronous Unbuffered (Unregistered)
Speed: 2400 MT/s
Manufacturer: Unknown
Serial Number: E438E36A
Asset Tag: Not Specified
Part Number: CT8G4DFS824A.C8FDD1
Rank: 1
Configured Memory Speed: 2400 MT/s
Minimum Voltage: 1.2 V
Maximum Voltage: 1.2 V
Configured Voltage: 1.2 V
Memory Technology: <OUT OF SPEC>
Memory Operating Mode Capability: None
Firmware Version: Unknown
Module Manufacturer ID: Unknown
Module Product ID: Unknown
Memory Subsystem Controller Manufacturer ID: Unknown
Memory Subsystem Controller Product ID: Unknown
Non-Volatile Size: None
Volatile Size: None
Cache Size: None
storage : 4x 10to wd red in raidz1-0
system is installed on a 128go ssh
system : FreeNAS-11.3-U4.1
i had the watchdog timeout error but corrected it by installing the driver
if_re.ko.zip (https://unlockforus.com/freenas-11-2-re0-watchdog-timeout-error/)
  • debug-freenas-20201102142958.tgz
jgreco
Resident Grinch
No, installing a different driver doesn't really fix problems with Realtek. The Realteks apparently use little hamsters in running wheels to power their chipsets, and often the hamsters are sickly or dead on arrival.
Please consider intalling an Intel CT desktop ethernet adapter. Despite the word "desktop," this (and most other) Intel card has a very well designed high performance chipset that works very well with FreeNAS.
You can feel free to search the forum for other examples of Realtek hamsters dying and very happy users who have replaced them with an Intel CT card. Please make sure you use a genuine Intel card, however. The fake Intel cards can operate just as badly as a Realtek.
Ihluvathar
Well in that case i where can i sign the mee too list ?
i will install the ct desktop adapter and add more ram. hope it will solve the issue
