Phantom Files
csearle
So I had an ambitious project. My objective was to up grade my Nas box from a regular PC, to an actual server. I migrated my setup over to my Levono 430T without issues.. When I first set up my original set up I created A dataset called "Media Files" In that I made a directory Called "Media Files". When I Copied all my necessary files to the "Media Files" all my files went to the root of my pool. (not to sure why)
Everything worked as I wanted to and I was happy with it, however in the back of my mind it was bugging me, so when I migrated my setup over to the 430T I was going to have to create a new Dataset "Media_Volume" and move everything over. When I did finally carried out this task, and made sure everything work for Plex perfectly, my plan was to delete the old files and Dataset.
I was able to delete all the old files from the dataset, however my Pool Storage shows that I have the original files sitting somewhere..
Im also having issues deleting the original dataset "Media Files"
I am hopping someone here can guid me in the right direction..
Patrick M. Hausen
Look for snapshots first ... it's in the UI under Storage.
csearle
Thank you!! Can I delete this snapshot?
Patrick M. Hausen
That's up to you to decide. You have not even shown us which dataset you have a snapshot or two of.
csearle
Just edited my first reply
Patrick M. Hausen
Well, if you are sure you definitely never want to roll back the "Media Library" dataset to the state of Jan 17th, you can delete that.
csearle
im defiantly sure, its deleted, still see no change in my Pool and dataset sizes
Patrick M. Hausen
Then please post the output of zfs list -t all. I can't promise I can look at that today but there are others around.
csearle
Here are the results of the command:
Last login: Thu Jan 21 01:47:16 on pts/1
FreeBSD 11.3-RELEASE-p9 (FreeNAS.amd64) #0 r325575+588899735f7(HEAD): Mon Jun 1 15:04:31 EDT 2020
FreeNAS (c) 2009-2020, The FreeNAS Development Team
All rights reserved.
FreeNAS is released under the modified BSD license.
For more information, documentation, help or support, go here:
http://freenas.org
Welcome to FreeNAS
Warning: settings changed through the CLI are not written to
the configuration database and will be reset on reboot.
root@SirNas[~]# zfs list -t all
NAME USED AVAIL REFER MOUNTPOINT
Candace 1.39T 377G 172K /mnt/Candace
Candace@Candace-2021-01-17_00-00 527G - 527G -
Candace/.system 1.49G 377G 649M legacy
Candace/.system@Candace-2020-04-06_00-00 64K - 96K -
Candace/.system@Candace-2020-04-07_00-00 64K - 96K -
Candace/.system@Candace-2020-04-08_00-00 64K - 96K -
Candace/.system@Candace-2020-04-09_00-00 72K - 642M -
Candace/.system@Candace-2020-04-10_00-00 72K - 642M -
Candace/.system@Candace-2020-04-11_00-00 72K - 642M -
Candace/.system@Candace-2021-01-17_00-00 72K - 649M -
Candace/.system/configs-4a7da323489644858925be23483a2e70 81.6M 377G 81.1M legacy
Candace/.system/configs-4a7da323489644858925be23483a2e70@Candace-2020-04-06_00-00 72K - 41.2M -
Candace/.system/configs-4a7da323489644858925be23483a2e70@Candace-2020-04-07_00-00 72K - 41.4M -
Candace/.system/configs-4a7da323489644858925be23483a2e70@Candace-2020-04-08_00-00 72K - 41.5M -
Candace/.system/configs-4a7da323489644858925be23483a2e70@Candace-2020-04-09_00-00 72K - 41.6M -
Candace/.system/configs-4a7da323489644858925be23483a2e70@Candace-2020-04-10_00-00 72K - 41.8M -
Candace/.system/configs-4a7da323489644858925be23483a2e70@Candace-2020-04-11_00-00 72K - 41.9M -
Candace/.system/configs-4a7da323489644858925be23483a2e70@Candace-2021-01-17_00-00 72K - 80.4M -
Candace/.system/cores 2.38M 377G 1.75M legacy
Candace/.system/cores@Candace-2020-04-06_00-00 0 - 1.71M -
Candace/.system/cores@Candace-2020-04-07_00-00 0 - 1.71M -
Candace/.system/cores@Candace-2020-04-08_00-00 0 - 1.71M -
Candace/.system/cores@Candace-2020-04-09_00-00 0 - 1.71M -
Candace/.system/cores@Candace-2020-04-10_00-00 0 - 1.71M -
Candace/.system/cores@Candace-2020-04-11_00-00 0 - 1.71M -
Candace/.system/cores@Candace-2021-01-17_00-00 56K - 1.75M -
Candace/.system/rrd-4a7da323489644858925be23483a2e70 147M 377G 28.1M legacy
Candace/.system/rrd-4a7da323489644858925be23483a2e70@Candace-2020-04-06_00-00 16.5M - 25.8M -
Candace/.system/rrd-4a7da323489644858925be23483a2e70@Candace-2020-04-07_00-00 16.5M - 25.9M -
Candace/.system/rrd-4a7da323489644858925be23483a2e70@Candace-2020-04-08_00-00 16.6M - 25.9M -
Candace/.system/rrd-4a7da323489644858925be23483a2e70@Candace-2020-04-09_00-00 16.6M - 25.9M -
Candace/.system/rrd-4a7da323489644858925be23483a2e70@Candace-2020-04-10_00-00 16.7M - 26M -
Candace/.system/rrd-4a7da323489644858925be23483a2e70@Candace-2020-04-11_00-00 17.0M - 26.3M -
Candace/.system/rrd-4a7da323489644858925be23483a2e70@Candace-2021-01-17_00-00 18.7M - 28.3M -
Candace/.system/samba4 1.21M 377G 332K legacy
Candace/.system/samba4@Candace-2020-04-06_00-00 76K - 308K -
Candace/.system/samba4@Candace-2020-04-07_00-00 76K - 308K -
Candace/.system/samba4@Candace-2020-04-08_00-00 76K - 308K -
Candace/.system/samba4@Candace-2020-04-09_00-00 76K - 308K -
Candace/.system/samba4@Candace-2020-04-10_00-00 76K - 308K -
Candace/.system/samba4@Candace-2020-04-11_00-00 84K - 316K -
Candace/.system/samba4@update--2020-06-27-20-12--11.3-U1 172K - 324K -
Candace/.system/samba4@Candace-2021-01-17_00-00 156K - 348K -
Candace/.system/syslog-4a7da323489644858925be23483a2e70 5.75M 377G 4.20M legacy
Candace/.system/syslog-4a7da323489644858925be23483a2e70@Candace-2020-04-06_00-00 192K - 2.02M -
Candace/.system/syslog-4a7da323489644858925be23483a2e70@Candace-2020-04-07_00-00 136K - 2.01M -
Candace/.system/syslog-4a7da323489644858925be23483a2e70@Candace-2020-04-08_00-00 144K - 2.02M -
Candace/.system/syslog-4a7da323489644858925be23483a2e70@Candace-2020-04-09_00-00 168K - 2.05M -
Candace/.system/syslog-4a7da323489644858925be23483a2e70@Candace-2020-04-10_00-00 136K - 2.04M -
Candace/.system/syslog-4a7da323489644858925be23483a2e70@Candace-2020-04-11_00-00 172K - 2.07M -
Candace/.system/syslog-4a7da323489644858925be23483a2e70@Candace-2021-01-17_00-00 352K - 4.11M -
Candace/.system/webui 88K 377G 88K legacy
Candace/.system/webui@Candace-2020-04-06_00-00 0 - 88K -
Candace/.system/webui@Candace-2020-04-07_00-00 0 - 88K -
Candace/.system/webui@Candace-2020-04-08_00-00 0 - 88K -
Candace/.system/webui@Candace-2020-04-09_00-00 0 - 88K -
Candace/.system/webui@Candace-2020-04-10_00-00 0 - 88K -
Candace/.system/webui@Candace-2020-04-11_00-00 0 - 88K -
Candace/.system/webui@Candace-2021-01-17_00-00 0 - 88K -
Candace/Chris Searle 107G 377G 106G /mnt/Candace/Chris Searle
Candace/Chris Searle@Candace-2021-01-17_00-00 1.10G - 105G -
Candace/Dawn Smith 123G 377G 123G /mnt/Candace/Dawn Smith
Candace/Dawn Smith@Candace-2021-01-17_00-00 676M - 122G -
Candace/Media Library 128K 377G 128K /mnt/Candace/Media Library
Candace/Media_Volume 526G 377G 526G /mnt/Candace/Media_Volume
Candace/Media_Volume@Candace-2021-01-17_00-00 304K - 134G -
Candace/Transmission 128G 377G 8.49G /mnt/Candace/Transmission
Candace/Transmission@Candace-2021-01-17_00-00 120G - 126G -
Candace/iocage 7.41G 377G 11.2M /mnt/Candace/iocage
Candace/iocage@Candace-2021-01-17_00-00 292K - 11.2M -
Candace/iocage/download 289M 377G 88K /mnt/Candace/iocage/download
Candace/iocage/download@Candace-2021-01-17_00-00 0 - 88K -
Candace/iocage/download/11.3-RELEASE 289M 377G 289M /mnt/Candace/iocage/download/11.3-RELEASE
Candace/iocage/download/11.3-RELEASE@Candace-2021-01-17_00-00 0 - 289M -
Candace/iocage/images 88K 377G 88K /mnt/Candace/iocage/images
Candace/iocage/images@Candace-2021-01-17_00-00 0 - 88K -
Candace/iocage/jails 6.03G 377G 88K /mnt/Candace/iocage/jails
Candace/iocage/jails@Candace-2021-01-17_00-00 0 - 88K -
Candace/iocage/jails/Plex 5.23G 377G 596K /mnt/Candace/iocage/jails/Plex
Candace/iocage/jails/Plex@ioc_update_11.3-RELEASE-p10_2020-12-19_13-30-14 540K - 580K -
Candace/iocage/jails/Plex@ioc_update_11.3-RELEASE-p14_2020-12-19_13-35-23 540K - 580K -
Candace/iocage/jails/Plex@Candace-2021-01-17_00-00 88K - 596K -
Candace/iocage/jails/Plex/root 5.23G 377G 3.10G /mnt/Candace/iocage/jails/Plex/root
Candace/iocage/jails/Plex/root@ioc_update_11.3-RELEASE-p10_2020-12-19_13-30-14 563M - 3.12G -
Candace/iocage/jails/Plex/root@ioc_update_11.3-RELEASE-p14_2020-12-19_13-35-23 431M - 3.18G -
Candace/iocage/jails/Plex/root@Candace-2021-01-17_00-00 355M - 3.31G -
Candace/iocage/jails/Transmission 820M 377G 356K /mnt/Candace/iocage/jails/Transmission
Candace/iocage/jails/Transmission@Candace-2021-01-17_00-00 76K - 356K -
Candace/iocage/jails/Transmission/root 820M 377G 781M /mnt/Candace/iocage/jails/Transmission/root
Candace/iocage/jails/Transmission/root@Candace-2021-01-17_00-00 38.9M - 783M -
Candace/iocage/log 160K 377G 96K /mnt/Candace/iocage/log
Candace/iocage/log@Candace-2021-01-17_00-00 64K - 96K -
Candace/iocage/releases 1.09G 377G 88K /mnt/Candace/iocage/releases
Candace/iocage/releases@Candace-2021-01-17_00-00 0 - 88K -
Candace/iocage/releases/11.3-RELEASE 1.09G 377G 88K /mnt/Candace/iocage/releases/11.3-RELEASE
Candace/iocage/releases/11.3-RELEASE@Candace-2021-01-17_00-00 0 - 88K -
Candace/iocage/releases/11.3-RELEASE/root 1.09G 377G 1.09G /mnt/Candace/iocage/releases/11.3-RELEASE/root
Candace/iocage/releases/11.3-RELEASE/root@Candace-2021-01-17_00-00 792K - 1.09G -
Candace/iocage/templates 88K 377G 88K /mnt/Candace/iocage/templates
Candace/iocage/templates@Candace-2021-01-17_00-00 0 - 88K -
freenas-boot 2.00G 12.0G 23K none
freenas-boot/ROOT 2.00G 12.0G 23K none
freenas-boot/ROOT/11.3-U3.2 2.00G 12.0G 1018M /
freenas-boot/ROOT/11.3-U3.2@2020-03-14-18:52:23 8.58M - 1016M -
freenas-boot/ROOT/11.3-U3.2@2020-06-27-16:09:25 8.98M - 1017M -
freenas-boot/ROOT/Initial-Install 1K 12.0G 1016M legacy
freenas-boot/ROOT/default 228K 12.0G 1017M legacy
root@SirNas[~]#
Patrick M. Hausen
The root dataset of your pool still has a snapshot of more than 500G:
You might want to delete that, too.
And please use "code" tags like so:
csearle
I am not familiar with Unix Based systems So not sure how to use "code Tags". However Deleting that snapshot did bring some space back.. Thank you very much @Patrick M. Hausen. Is there a way to edit the snapshots so I pick witch dataset to snapshot? Now to Find the solution to my Dataset that I cannot delete
Patrick M. Hausen
Code tags here in the forum. Formatting ... it's in the toolbar when you write a post.
csearle
Ahhh its a form thing, understood I misunderstood..
csearle
Finally Deleted my "Media File" Dataset there was an extra space after "Media File " and my phantom space did come back thank you @Patrick M. Hausen
