Permissions inside a volume
Freesnofla
Well guys; I'm bit hopeless for the moment as I'm not sure what is the reason that I can't any longer mount my freenas drive.
I did the following so far:
  1. Created /mount/RAID1
  2. Created /mount/RAID1/Data
  3. Created /mount/RAID1/Data/owncloud (owner/usergroup is www)
  4. Created /mount/RAID1/Media/Movie (owner:root; group: wheel)
  5. Created /mount/RAID1/Media/Music (owner:root; group: wheel)
  6. Created /mount/RAID1/Media/Pictures (owner:root; group: wheel)
Then I created some NFS shares:
  1. Data
  2. Maproot group (N/A)
  3. Mapall user (root)
  4. Path: /mnt/RAID1/Data/owncloud
  5. Media:
  6. Maproot group (N/A)
  7. Mapall user (root)
  8. Path: /mnt/RAID1/Media
Do I have to create users for each of them which I like to get to the freenas, I have 3 users so far and would like to mount each of them into Ubuntu. I wrote the tutorial several times but I can't fix that task yet.
regards
freenassnofla
Freesnofla
Anybody out there who can help me to fix that task, I can't really use Freenas yet as I can't get access to the box.
D
dlavigne
Guest
Do you get an error when you try to mount the shares on the Ubuntu system? If so, post the command you are using and the resulting error.
