permissions disappear
freenasbbs
Freenas version 9.2.0 --9.2.1.3 (32 bit/64bit)
Directory name 23
Directory own :FileAdmin
Directory group :wheel
I set directory 23 permissions like :
chmod 770 23
setfacl -m u:ManB:modify_set:fd:allow 23
setfacl -m g:ProdMan:modify_set:fd:allow 23
Then it shows it’s permissions like (Fig1),it is right
In order to record which one & do what in my nas,i set some auxiliary parameters in share folder (like this)
vfs objects = full_audit
full_audit:prefix = %u|%I|%m|%S
full_audit:success = mkdir rmdir write rename
full_audit:failure = none
full_audit:facility = LOCAL7
full_audit:priority = ALERT
(see : http://forums.freenas.org/index.php...-when-do-what-on-the-server.17496/#post-94141)
The Problem Is
After i reboot cifs,file’s permissions had changed (Fig2),all permissions which set by “setfacl” disappear,why?
Thank you !
anodos
Sambassador
See Samba bug report here: https://bugzilla.samba.org/show_bug.cgi?id=9956
Short version - FreeNAS middleware automatically generates an smb4.conf file with 'vfs objects = zfsacl'. When you add an additional parameter 'vfs objects = full_audit', the previous parameter is invalidated. To get around this you need to review your smb4.conf file for all parameters set regarding vfs objects, then create a full one-liner in the 'auxiliary parameters'. For example 'vfs objects = zfsacl full_audit'
I'm not in front of a freenas server and so I can't tell you what the standard vfs options are. You will need to do that bit of legwork yourself otherwise you will probably end up breaking other things.
