Codeslayer
- Jul 11, 2014
I'm planning to build a small FreeNAS station using this board:
http://www.sapphiretech.com/presentation/product/?cid=2&gid=1047&sgid=1045&pid=1662&psn=&lid=1&leg=0
Since it has only 4 SATA ports and I want to use them for 4x 1TB HDDs I wonder if it's possible to install FreeNAS on a fast USB stick and boot from it permanently.
Generally I would like to avoid buying another SATA controller just for the boot drive.
Just in case this is a feasible way to run FreeNAS I still have few question:
1. Which size should I use for the system drive (usb stick) to have enough space for the future?
2. Which amount of RAM should I consider to install? Would be 4GBs enough?
3. Is this AMD CPU fast enough to use the system as a DLNA server and playback SD and 720p videos?
