zfs reports 5 permanent errors in the pool:
backup# zpool status -v
pool: store1
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://www.sun.com/msg/ZFS-8000-8A
scan: scrub repaired 0 in 17h35m with 0 errors on Tue Aug 20 05:45:46 2013
NAME STATE READ WRITE CKSUM
store1 ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/7e3d623f-9190-11e2-b8f7-0019990d0a17 ONLINE 0 0 0
gptid/7eca7240-9190-11e2-b8f7-0019990d0a17 ONLINE 0 0 0
gptid/77cd1366-9556-11e2-858b-0019990d0a17 ONLINE 0 0 0
store1/hosting-backups:<0x1880d1d>
store1/hosting-backups:<0x1ea6932>
store1/hosting-backups:<0x8adc36>
store1/hosting-backups:<0x2414e3e>
store1/hosting-backups:<0x2407a3e>
What are my options? If there's a faulty disk I would gladly replace it, but ZFS doesn't tell me which disk is causing this problem. And what's with the so called "files":
Those aren't filenames but hex codes. What's up with that? How can I delete those files, or repair the filesystem?
Thanks in advance!
Regards,
Joern
pool: store1
state: ONLINE
store1 ONLINE 0 0 0
Thanks in advance!
Regards,
Joern
