Performance issues
Hi everyone,
I have built a storage server, that I would like to run FreeNAS on.
The specs are:
Mainboard: SuperMicro X10SRL-F
CPU: Hexacore Xeon CPU
RAM: 128GB DDR4 ECC RAM
Controller: LSI SAS 9300-8i Host Bus Adapter
Disks: 1x Samsung 128GB SSD for FreeNAS installation
4x Samsung SM863 960GB SSD
I have done a clean installation, made a Striped Mirror of the 4 SSD's.
The problem is that the volume is only performing about 150 MB/s in write speed and about half that in read speed.
I used the following commands to do the testing:
# dd if=/dev/zero of=testfile bs=1024 count=50000
# dd if=testfile of=/dev/zero bs=1024 count=50000
Can anyone in here point me in a direction to get it running faster?
I mean the disk themselves should perform around 500 MB/s, and I presume RAID 10 should perform on par or even faster, right?
I would appreciate any input, that can help resolve this issue.
Thank you.
Best regards,
Ulrich
You may want to consider how block size affects your write speed. Here is my four-drive SSD striped mirror...
$ dd if=/dev/zero of=testfile bs=1024 count=100000
102400000 bytes transferred in 0.776452 secs (131,881,934 bytes/sec)
$ dd if=/dev/zero of=testfile bs=2048 count=100000
204800000 bytes transferred in 0.834657 secs (245,370,267 bytes/sec)
$ dd if=/dev/zero of=testfile bs=4096 count=100000
409600000 bytes transferred in 0.914390 secs (447,948,863 bytes/sec)
$ dd if=/dev/zero of=testfile bs=8192 count=100000
819200000 bytes transferred in 1.115028 secs (734,690,133 bytes/sec)
$ dd if=/dev/zero of=testfile bs=16384 count=100000
1638400000 bytes transferred in 1.512976 secs (1,082,898,748 bytes/sec)
$ dd if=/dev/zero of=testfile bs=32768 count=100000
3276800000 bytes transferred in 2.233185 secs (1,467,321,302 bytes/sec)
Also to consider... your stream of zeros is highly-compressible. Do you have compression turned on for that pool?
Cheers,
Matt
Bidule0hm
Server Electronics Sorcerer
Cheers,
Matt
Be careful, this isn't a valid test result as you don't copy the same data quantity each time...
For the purposes of spit-balling an example, it was close enough. But, of course, you are right. Below is an example with the block count adjusted downward to offset the increased block size.
102400000 bytes transferred in 0.800337 secs (127,946,129 bytes/sec)
$ dd if=/dev/zero of=testfile bs=2048 count=50000
102400000 bytes transferred in 0.411407 secs (248,901,943 bytes/sec)
$ dd if=/dev/zero of=testfile bs=4096 count=25000
102400000 bytes transferred in 0.231780 secs (441,798,612 bytes/sec)
$ dd if=/dev/zero of=testfile bs=8192 count=12500
102400000 bytes transferred in 0.137086 secs (746,976,816 bytes/sec)
$ dd if=/dev/zero of=testfile bs=16384 count=6250
102400000 bytes transferred in 0.093142 secs (1,099,396,235 bytes/sec)
$ dd if=/dev/zero of=testfile bs=32768 count=3125
102400000 bytes transferred in 0.070131 secs (1,460,128,267 bytes/sec)
Not much change.
Cheers,
Matt
Bidule0hm
Yep, just a question of lisibility, now we can clearly see there's a more than a 10 ratio between 1k and 32k ;)
