Skuloth
- Jul 16, 2017
Hey all,
Over the last week I've been dealing with some sudden performance issues with my freenas box. I have a hard time believing its related, but my performance issues began as soon as I updated to freenas 11 from 9.10 u4.
I dont have benchmarks from before hand, but I could fully saturate my 1 gig connection transferring files to my desktop from the server, and now it struggles to hit ~60MB/s. On FN11 the webui was incredibly sluggish taking 15-20 seconds to load panels compared to nearly instant previously.
I dropped back to 9.10u4 after a scheduled scrub completed (which returned no errors) to better webui performance and similar disk performance, but still significantly worse than pre update.
As far as config changes, nothing has been done aside from the obvious update to 11. I dusted out the box between the scrub completion and the drop back to 9.10 and will be running memtest when I take it down tomorrow or wednesday to replace the fans in my case.
Hardware:
Supermicro X10SDV-4c-TLN2f-0
Xeon d-1521
2x16gb samsung DDR4 ecc ram
6x8TB WD reds in raid z2
I've checked smart data and plan to keep an eye on it over the next couple weeks, but saw no issues. Temps are within reason. Will be running memtest like I mentioned.
I'm mainly looking for suggestion about what to look into since I'm out of ideas currently.
Any help would be appreciated
-Skuloth
Hardware:
Xeon d-1521
-Skuloth
