dacabdi
- Dec 10, 2021
I am considering setting up a NAS in a Dell R710 with 2-tiered cache (48 GB RAM -> 500GB NVME SSD -> 4x8TB spinning media). Before that, I am familiarizing myself with OpenZFS and TrueNAS. Today I setup a VM on HyperV, created 4 virtual disks to simulate the members of a zpool's data vdev and passed them along just to get a feeling of the functional-logical setup. I understand that this is not a setup to test performance per se, but at least I can observe relative performance, all virtual disks block files being equal. If I setup a zpool with only 1 data disk (remember, virtual), and a separate UFS partition on another disk (same, virtual), I observe double the performance on the UFS partition. So, both underlying devices basically should offer the same performance, however low due to it being through the entire virtualization stack of HyperV, but relatively equal; yet, the performance on ZFS is half of that on a disk formatted with UFS. Is this expected due to some angle I am missing about ZFS? (I also tried creating a pool with more members, but in this case, since all virtual disks block files are hosted on the same drive of the host, I actually would expect less performance).
Setup
root@truenas[/mnt/data3]# zpool status
pool: boot-pool
state: ONLINE
NAME STATE READ WRITE CKSUM
boot-pool ONLINE 0 0 0
da0p2 ONLINE 0 0 0
errors: No known data errors
pool: data-alone
state: ONLINE
data-alone ONLINE 0 0 0
gptid/7c105c5b-5a19-11ec-a99c-00155d00b402 ONLINE 0 0 0
root@truenas[/mnt/data3]# gpart show
=> 40 67108784 da0 GPT (32G)
40 532480 1 efi (260M)
532520 66551808 2 freebsd-zfs (32G)
67084328 24496 - free - (12M)
=> 40 33554352 da1 GPT (16G)
40 88 - free - (44K)
128 33554264 1 freebsd-zfs (16G)
=> 40 209715120 da6 GPT (100G)
40 209715120 1 freebsd-ufs (100G)
=> 40 209715120 da3 GPT (100G)
128 4194304 1 freebsd-swap (2.0G)
4194432 205520728 2 freebsd-zfs (98G)
=> 40 209715120 da4 GPT (100G)
=> 40 209715120 da2 GPT (100G)
#Results
root@truenas[/mnt/data3]# fio --name=write_throughput --directory=/mnt/data-alone --numjobs=1 \
--size=10G --time_based --runtime=60s --ramp_time=2s \
--direct=0 --verify=0 --bs=4M --iodepth=64 --rw=write \
--group_reporting=1
write_throughput: (g=0): rw=write, bs=(R) 4096KiB-4096KiB, (W) 4096KiB-4096KiB, (T) 4096KiB-4096KiB, ioengine=psync, iodepth=64
fio-3.27
Starting 1 process
write_throughput: Laying out IO file (1 file / 10240MiB)
^Cbs: 1 (f=1): [W(1)][29.0%][w=1401MiB/s][w=350 IOPS][eta 00m:44s]
fio: terminating on signal 2
write_throughput: (groupid=0, jobs=1): err= 0: pid=4294: Fri Dec 10 17:03:39 2021
write: IOPS=350, BW=1404MiB/s (1472MB/s)(22.6GiB/16484msec); 0 zone resets
clat (usec): min=606, max=43728, avg=2693.70, stdev=2015.40
lat (usec): min=626, max=43743, avg=2843.31, stdev=2163.25
clat percentiles (usec):
| 1.00th=[ 668], 5.00th=[ 742], 10.00th=[ 807], 20.00th=[ 1287],
| 30.00th=[ 1942], 40.00th=[ 2180], 50.00th=[ 2376], 60.00th=[ 2573],
| 70.00th=[ 2900], 80.00th=[ 3425], 90.00th=[ 4424], 95.00th=[ 5800],
| 99.00th=[10552], 99.50th=[12911], 99.90th=[19530], 99.95th=[29492],
| 99.99th=[43779]
bw ( MiB/s): min= 1086, max= 1571, per=100.00%, avg=1408.52, stdev=98.63, samples=32
iops : min= 271, max= 392, avg=351.66, stdev=24.70, samples=32
lat (usec) : 750=5.83%, 1000=11.34%
lat (msec) : 2=14.97%, 4=54.07%, 10=12.67%, 20=1.04%, 50=0.09%
cpu : usr=5.07%, sys=87.74%, ctx=15850, majf=0, minf=1
IO depths : 1=100.0%, 2=0.0%, 4=0.0%, 8=0.0%, 16=0.0%, 32=0.0%, >=64=0.0%
submit : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
complete : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
issued rwts: total=0,5785,0,0 short=0,0,0,0 dropped=0,0,0,0
latency : target=0, window=0, percentile=100.00%, depth=64
Run status group 0 (all jobs):
WRITE: bw=1404MiB/s (1472MB/s), 1404MiB/s-1404MiB/s (1472MB/s-1472MB/s), io=22.6GiB (24.3GB), run=16484-16484msec
root@truenas[/mnt/data3]# fio --name=write_throughput --directory=/mnt/data3 --numjobs=1 --size=10G --time_based --runtime=60s --ramp_time=2s --direct=0 --verify=0 --bs=4M --iodepth=64 --rw=write --group_reporting=1
fio-3.27
Starting 1 process
fio: io_u error on file /mnt/data3/write_throughput.0.0: No space left on device: write offset=8568963072, buflen=4194304
fio: pid=4304, err=28/file:io_u.c:1841, func=io_u error, error=No space left on device
write_throughput: (groupid=0, jobs=1): err=28 (file:io_u.c:1841, func=io_u error, error=No space left on device): pid=4304: Fri Dec 10 17:04:05 2021
write: IOPS=710, BW=2839MiB/s (2977MB/s)(3464MiB/1220msec); 0 zone resets
clat (usec): min=829, max=24092, avg=1374.16, stdev=1531.18
lat (usec): min=848, max=24130, avg=1398.46, stdev=1531.79
| 1.00th=[ 873], 5.00th=[ 914], 10.00th=[ 938], 20.00th=[ 971],
| 30.00th=[ 1012], 40.00th=[ 1045], 50.00th=[ 1090], 60.00th=[ 1139],
| 70.00th=[ 1188], 80.00th=[ 1287], 90.00th=[ 1500], 95.00th=[ 2671],
| 99.00th=[11600], 99.50th=[13304], 99.90th=[23987], 99.95th=[23987],
| 99.99th=[23987]
bw ( MiB/s): min= 2858, max= 2921, per=100.00%, avg=2889.63, stdev=44.37, samples=2
iops : min= 714, max= 730, avg=722.00, stdev=11.31, samples=2
lat (usec) : 1000=26.07%
lat (msec) : 2=66.78%, 4=5.42%, 10=0.35%, 20=1.15%, 50=0.12%
cpu : usr=1.07%, sys=83.76%, ctx=65, majf=0, minf=4
complete : 0=0.1%, 4=99.9%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
issued rwts: total=0,867,0,0 short=0,0,0,0 dropped=0,0,0,0
WRITE: bw=2839MiB/s (2977MB/s), 2839MiB/s-2839MiB/s (2977MB/s-2977MB/s), io=3464MiB (3632MB), run=1220-1220msec
