Littlejd97
 - Dec 10, 2021
I was wondering if someone could help me understand if this is just expected performance, or if there is something misconfigured.
I have 2 4TB WD Red CMR (WD40EFRX) drives in a Mirror, and I would expect sequentially 100MB/s+ per drive, but I'm getting far less than that when running tests.
I disabled all services NFS/iSCSI, etc the ran these tests on the machine itself. I also set the `primarycache` to `metadata`
While running these tests, I checked `zpool iostat`
During the read test
And write test
These numbers just seem way too low.
root@truenas[/mnt/NAS]# fio --filename=/mnt/NAS/test.file --name=sync_seqread --rw=read --bs=4M --direct=1 --sync=1 --numjobs=1 --ioengine=psync --iodepth=1 --refill_buffers --size=1G --loops=10 --group_reporting
sync_seqread: (g=0): rw=read, bs=(R) 4096KiB-4096KiB, (W) 4096KiB-4096KiB, (T) 4096KiB-4096KiB, ioengine=psync, iodepth=1
fio-3.28
Starting 1 process
sync_seqread: Laying out IO file (1 file / 1024MiB)
sync_seqread: (groupid=0, jobs=1): err= 0: pid=8979: Wed Nov  2 20:22:40 2022
  read: IOPS=22, BW=88.2MiB/s (92.5MB/s)(10.0GiB/116044msec)
    clat (usec): min=243, max=841757, avg=45324.58, stdev=33266.73
     lat (usec): min=243, max=841758, avg=45325.38, stdev=33266.80
    clat percentiles (usec):
     |  1.00th=[   260],  5.00th=[   277], 10.00th=[   441], 20.00th=[ 41681],
     | 30.00th=[ 43779], 40.00th=[ 45351], 50.00th=[ 46924], 60.00th=[ 47973],
     | 70.00th=[ 49546], 80.00th=[ 51643], 90.00th=[ 54789], 95.00th=[ 65274],
     | 99.00th=[175113], 99.50th=[270533], 99.90th=[304088], 99.95th=[438305],
     | 99.99th=[843056]
   bw (  KiB/s): min=15937, max=2096956, per=100.00%, avg=91020.76, stdev=141078.11, samples=226
   iops        : min=    3, max=  511, avg=21.61, stdev=34.43, samples=226
  lat (usec)   : 250=0.23%, 500=12.58%, 750=0.39%
  lat (msec)   : 50=60.59%, 100=24.41%, 250=1.21%, 500=0.55%, 1000=0.04%
  cpu          : usr=0.01%, sys=0.96%, ctx=8935, majf=0, minf=1024
  IO depths    : 1=100.0%, 2=0.0%, 4=0.0%, 8=0.0%, 16=0.0%, 32=0.0%, >=64=0.0%
     submit    : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
     complete  : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
     issued rwts: total=2560,0,0,0 short=0,0,0,0 dropped=0,0,0,0
     latency   : target=0, window=0, percentile=100.00%, depth=1
Run status group 0 (all jobs):
   READ: bw=88.2MiB/s (92.5MB/s), 88.2MiB/s-88.2MiB/s (92.5MB/s-92.5MB/s), io=10.0GiB (10.7GB), run=116044-116044msec
root@truenas[/mnt/NAS]#Code:
root@truenas[/mnt/NAS]# fio --filename=/mnt/NAS/test.file --name=sync_seqwrite --rw=write --bs=4M --direct=1 --sync=1 --numjobs=1 --ioengine=psync --iodepth=1 --refill_buffers --size=5G --loops=1 --group_reporting | tee -a "${LOGFILE}"
sync_seqwrite: (g=0): rw=write, bs=(R) 4096KiB-4096KiB, (W) 4096KiB-4096KiB, (T) 4096KiB-4096KiB, ioengine=psync, iodepth=1
fio-3.28
Starting 1 process
sync_seqwrite: Laying out IO file (1 file / 5120MiB)
sync_seqwrite: (groupid=0, jobs=1): err= 0: pid=8655: Wed Nov  2 20:19:21 2022
  write: IOPS=8, BW=34.8MiB/s (36.5MB/s)(5120MiB/147112msec); 0 zone resets
    clat (msec): min=21, max=281, avg=114.41, stdev=35.53
    clat percentiles (msec):
     |  1.00th=[   78],  5.00th=[   88], 10.00th=[   89], 20.00th=[   92],
     | 30.00th=[   99], 40.00th=[  100], 50.00th=[  102], 60.00th=[  107],
     | 70.00th=[  111], 80.00th=[  126], 90.00th=[  169], 95.00th=[  203],
     | 99.00th=[  241], 99.50th=[  253], 99.90th=[  275], 99.95th=[  284],
     | 99.99th=[  284]
   bw (  KiB/s): min=15603, max=49053, per=100.00%, avg=35672.08, stdev=8180.57, samples=285
   iops        : min=    3, max=   11, avg= 7.97, stdev= 2.05, samples=285
  lat (msec)   : 50=0.39%, 100=46.72%, 250=52.27%, 500=0.62%
  cpu          : usr=0.47%, sys=0.45%, ctx=2671, majf=0, minf=0
     issued rwts: total=0,1280,0,0 short=0,0,0,0 dropped=0,0,0,0
  WRITE: bw=34.8MiB/s (36.5MB/s), 34.8MiB/s-34.8MiB/s (36.5MB/s-36.5MB/s), io=5120MiB (5369MB), run=147112-147112msec
root@truenas[/mnt/NAS]While running these tests, I checked `zpool iostat`
                                                  capacity     operations     bandwidth
pool                                            alloc   free   read  write   read  write
NAS                                             2.68T   972G    655      0  81.9M      0
  mirror-0                                      2.68T   972G    655      0  81.9M      0
    gptid/afc545f7-75ad-11eb-9241-f9ace32b146a      -      -    329      0  41.2M      0
    gptid/aff57292-75ad-11eb-9241-f9ace32b146a      -      -    325      0  40.7M      0
----------------------------------------------  -----  -----  -----  -----  -----  -----And write test
NAS                                             2.68T   969G      0    364      0  71.4M
  mirror-0                                      2.68T   969G      0    364      0  71.4M
    gptid/afc545f7-75ad-11eb-9241-f9ace32b146a      -      -      0    182      0  35.7M
    gptid/aff57292-75ad-11eb-9241-f9ace32b146a      -      -      0    182      0  35.7M
----------------------------------------------  -----  -----  -----  -----  -----  -----These numbers just seem way too low.
