ProblematicLlama
- Jan 25, 2015
I have a pending sector on one of my disks (the other 4 are completely healthy). I have read that I can force reallocation of a pending sector using DD to attempt to write to the bad sector. I found someone's handy guide here: https://dekoder.wordpress.com/2014/10/08/fixing-freenas-currently-unreadable-pending-sectors-error/
One section that's thrown a small spanner in the works for me, however, is that it says to get the sector size. In their example, the logical and physical sector size is the same - 512. However, on my disk, the sector size reports
If I'm running dd to write to the bad sector, what should I set the bs to?
Also the command in the guide doesn't seem to actually refer to the sector size, not sure if it's a mistake or if it's legit. Their command shows (note: I'm keeping the example numbers just for consistency with the guide, obviously the LBA is different in my case):
which appears to be using the LBA for the bs but nothing for the seek. Is this legit? The way everything before it is worded implies the command should go something more like this:
Below is the output of my SMART report (smartctl -q noserial -a /dev/ada0)
So my questions really are:
1) What command should I be using to force reallocate this sector? Should I even be doing this or is it safer to just leave it and let the system attempt to write to the bad sector in it's own time?
2) While it's there, can you spot anything else alarming in my SMART output that indicates I need to replace this drive immediately, or am I relatively safe to keep it in there?
Thanks in advance for your help
dd if=/dev/zero of=/dev/ada2 bs=892134344 count=1 seek= conv=noerror,sync
dd if=/dev/zero of=/dev/ada2 bs=512 count=1 seek=892134344 conv=noerror,sync
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68EUZN0
Firmware Version: 82.00A82
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Wed Aug 17 14:35:20 2016 BST
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (40080) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 402) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 32
3 Spin_Up_Time 0x0027 179 176 021 Pre-fail Always - 6016
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 17
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 084 084 000 Old_age Always - 11716
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 17
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 4
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 249
194 Temperature_Celsius 0x0022 119 113 000 Old_age Always - 31
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 2
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 11704 -
# 2 Short offline Completed without error 00% 11680 -
# 3 Short offline Completed without error 00% 11656 -
# 4 Short offline Completed without error 00% 11634 -
# 5 Short offline Completed without error 00% 11608 -
# 6 Short offline Completed without error 00% 11585 -
# 7 Short offline Completed without error 00% 11536 -
# 8 Short offline Completed: read failure 90% 11513 105062840
# 9 Short offline Completed: read failure 90% 11489 105062840
#10 Short offline Completed: read failure 90% 11465 105062840
#11 Short offline Completed: read failure 10% 11441 105062840
#12 Short offline Completed without error 00% 11417 -
#13 Extended offline Completed: read failure 90% 11392 105062840
#14 Short offline Completed: read failure 90% 11369 105062840
#15 Short offline Completed: read failure 90% 11345 105062840
#16 Short offline Completed: read failure 10% 11321 105062840
#17 Short offline Completed: read failure 90% 11297 105062840
#18 Short offline Completed: read failure 90% 11273 105062841
#19 Short offline Completed: read failure 90% 11249 105062840
#20 Short offline Completed without error 00% 11201 -
#21 Extended offline Completed: read failure 90% 11190 105059376
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
