PEAR Installation
lanky8804
Hi
i am trying to install PEAR to my jail but am having issues was wondering whether anyone had any experience of this package?
http://pear.php.net/
I already have PHP, mySQL and Apache installed.
Thanks
D
dlavigne
Guest
Please post the commands you used and the errors you're getting.
lanky8804
1st code: wget http://pear.php.net/go-pear.phar
2nd code: php go-pear.phar
Gets stuck on XML Extension not found.
To give you some background i am attempting to install NewzNab
root@web:/ # wget http://pear.php.net/go-pear.phar
--2014-01-12 15:21:52-- http://pear.php.net/go-pear.phar
Resolving pear.php.net (pear.php.net)... 5.77.39.20
Connecting to pear.php.net (pear.php.net)|5.77.39.20|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 4082712 (3.9M) [application/octet-stream]
Saving to: 'go-pear.phar.2'
100%[=================================================================================>] 4,082,712 5.15MB/s in 0.8s
2014-01-12 15:21:53 (5.15 MB/s) - 'go-pear.phar.2' saved [4082712/4082712]
root@web:/ # php go-pear.phar
Below is a suggested file layout for your new PEAR installation. To
change individual locations, type the number in front of the
directory. Type 'all' to change all of them or simply press Enter to
accept these locations.
1. Installation base ($prefix) : /usr/local
2. Temporary directory for processing : /tmp/pear/install
3. Temporary directory for downloads : /tmp/pear/install
4. Binaries directory : /usr/local/bin
5. PHP code directory ($php_dir) : /usr/local/share/pear
6. Documentation directory : /usr/local/docs
7. Data directory : /usr/local/data
8. User-modifiable configuration files directory : /usr/local/cfg
9. Public Web Files directory : /usr/local/www
10. Tests directory : /usr/local/tests
11. Name of configuration file : /usr/local/etc/pear.conf
1-11, 'all' or Enter to continue:
Beginning install...
root@web:/ #
lanky8804
This is how far ive got so far with NewzNab
D
dlavigne
Guest
For the dependencies, it is easiest to install them using pkgs/ports, and once the dependencies are met, to try the install script. There is a port/pkg for pear at devel/pear.
lanky8804
Thanks,
Got PEAR installed using following commands
cd /usr/ports/devel/pear
make install
