Panic VERIFY3 failed - metaslabs problems?
Guguano
Version: TureNAS 13.0-U3.1
Specs:
Motherboard: MSI B450 Tomahawk Max
CPU: Ryzen 7 3800X
RAM: 32GB DDR4 3200MHz
Hard drives:
  • 3x WD Elements 12TB Desktop External Hard Drive (removed from enclosure and connected using SATA)
  • 3x Seagate Exos X20 20TB SATA 6Gb/s 7200 RPM
  • SAMSUNG 970 EVO Plus NVMe SSD 1TB (in a SABRENT USB 3.2 10Gbps Type C Enclosure for NVMe SSDs)
I was running out of storage and decided to purchase more drives, I ended up getting 3 Seagate Exos 20TB HDDs. Shortly after installing them I updated to TureNAS 13.0-U3.1. Had no issues until I ran into a network disconnect. When I rebooted to fix the network issue, I got stuck in a bootloop. When my system reaches the point of trying to import my storage pool, I get “panic: VERIFY3(rs_get_start(rs, rt) <= start) failed (3557780594688 <= 3557779103744)”. I have attached a photo of the full shell output.
I would really appreciate help with what I should do from here to get my pool to import again. Please let me know if there is any more information I can provide that would be helpful.
