PANIC Reboots
Omakase
I am continuing to experience ongoing, sporadic and annoying system reboots with my FreeNAS server.
Each time I get the same thing in the debug output:
solaris assert: BSWAP_32(sa_hdr_phys->sa_magic) == SA_MAGIC, file: /freenas-releng/freenas/_BE/os/sys/cddl/contrib/opensolaris/uts/common/fs/zfs/sa.c, line: 1285
Does anyone have any idea what causes the above error? The system comes back up, but it's rather frustrating as it's used by 7 staff members and it happens completely randomly.
System Specs
Motherboard: ASUS Prime Z390-A
CPU: Intel Core i5-9600k
RAM: 64GB (4x16GB) Corsair LPX DDR4 3000mhz
Boot Drive: 2 x Samsung EVO 860 500GB Mirrored
HBA: 2 x HP H220 flashed to LSI 9207-8i IT mode
Storage Drives: 6 x 8TB Seagate Ironwolf (2 x 3 Z1, one on each controller)
Freenas Version: 11.2-U5
If any other output files would be of help, let me know!
Thanks in advance! This is driving me nuts
Meyers
The first thing that jumps out to me is that you're not using ECC memory. The recommendation is to use ECC memory if you care about your data. I wouldn't run ZFS without it. Make sure you have good backups.
Beyond this, I recommend opening a ticket.
Omakase
Sorry for the delay in responding, I lost track of myself. That said, I just ordered some replacement hardware to switch to ECC and will cross my fingers.
As for the ticket, i've had that created since June 27th, but it's been giving low priority so no response yet.
