Pango-WARNING /usr/local/bin/python /usr/local/bin/graph.py
Every 5 minutes I receive this message from : Cron <root@freenas> /usr/local/bin/python /usr/local/bin/graph.py
System updated from 8.0.3 to 8.3 amd64 with GUI
My graphics are not readable too :(
Please help me...
(process:54067): Pango-WARNING **: failed to create cairo scaled font, expect ugly output. the offending font is 'Bitstream Vera Sans Mono 8'
(process:54067): Pango-WARNING **: font_face status is: <unknown error status>
(process:54067): Pango-WARNING **: scaled_font status is: <unknown error status>
(process:54067): Pango-WARNING **: shaping failure, expect ugly output. shape-engine='BasicEngineFc', font='Bitstream Vera Sans Mono 8', text=' '
(process:54067): Pango-WARNING **: failed to create cairo scaled font, expect ugly output. the offending font is 'Bitstream Vera Sans Mono 7'
(process:54067): Pango-WARNING **: shaping failure, expect ugly output. shape-engine='BasicEngineFc', font='Bitstream Vera Sans Mono 7', text='0'
(process:54067): Pango-WARNING **: failed to create cairo scaled font, expect ugly output. the offending font is 'Bitstream Vera Sans Mono 9'
(process:54067): Pango-WARNING **: shaping failure, expect ugly output. shape-engine='BasicEngineFc', font='Bitstream Vera Sans Mono 9', text='Interface Traffic (re0)'
(process:54067): Pango-WARNING **: failed to create cairo scaled font, expect ugly output. the offending font is 'Bitstream Vera Sans Mono 5.4990234375'
(process:54067): Pango-WARNING **: shaping failure, expect ugly output. shape-engine='BasicEngineFc', font='Bitstream Vera Sans Mono 5.4990234375', text='RRDTOOL / TOBI OETIKER'
upgrade to 8.3 OK
Looks like your install is corrupted. Did you try a new usb stick?
A new install/upgrade with the .iso and it works but...
After upgrade, I have entered these two commands :
/etc/rc.d/ix-smartd start
/etc/rc.d/ix-nginx start
So nginx and smartd are OK
Thanks
I had the same problem with upgrade to 8.3.1 -p2...
There is a solution without reinstalling :
[root@freenas] /# fc-cache -f -v
and after a reboot all is good :)
