This is my first post, and I wish it had been a more pleasant issue to write about.
I bought 4 new TOSHIBA N300 10TB NAS drives 21st of december 2019. The disk drives, ZFS and my FreeNAS system has run excellent until now.
Two of them failed SMART test in the beginning of May with the follwing alert type:
I started to backup the 20+TB files. So this saturday, the computer store replaced the drives without any problem, and I started all over to create a new pool and restore my files.
But, this morning, FreeNAS again warns (critical) for two of the disk drives, one of them I bought in december and one of the replaced (and new) one I got this saturday. The disk is not even 48 hours old. I really do not know what is going on. Bad luck? 4 out of 6 drives got this error. Should I expect the last two of them to fail as well?
Anyone else got problem with Toshiba N300 NAS drives in FreeNAS?
The SMART output:
CRITICAL Device: /dev/da11 [SAT], Failed SMART usage Attribute: 7 Seek_Error_Rate.. Mon, 5 May 2020 06:30:32 AM (Europe/Stockholm)
The SMART output:
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p7 amd64] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model: TOSHIBA HDWG11A
Serial Number: 2030A0RFFATG
LU WWN Device Id: 5 000039 9f8c8c0e5
Firmware Version: 0603
User Capacity: 10,000,831,348,736 bytes [10.0 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon May 18 08:14:43 2020 CEST
SMART support is: Enabled
SMART Status not supported: Incomplete response, ATA output registers missing
SMART overall-health self-assessment test result: FAILED!
Drive failure expected in less than 24 hours. SAVE ALL DATA.
Warning: This result is based on an Attribute check.
See vendor-specific Attribute list for failed Attributes.
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
been run.
data collection: ( 120) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: (1028) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
2 Throughput_Performance 0x0005 100 100 050 Pre-fail Offline - 0
3 Spin_Up_Time 0x0027 100 100 001 Pre-fail Always - 9546
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 2
5 Reallocated_Sector_Ct 0x0033 100 100 050 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 030 030 050 Pre-fail Always FAILING_NOW 0
8 Seek_Time_Performance 0x0005 100 100 050 Pre-fail Offline - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 42
10 Spin_Retry_Count 0x0033 100 100 030 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 2
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 1
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 2
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 26 (Min/Max 21/27)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
220 Disk_Shift 0x0002 100 100 000 Old_age Always - 219676699
222 Loaded_Hours 0x0032 100 100 000 Old_age Always - 42
223 Load_Retry_Count 0x0032 100 100 000 Old_age Always - 0
224 Load_Friction 0x0022 100 100 000 Old_age Always - 0
226 Load-in_Time 0x0026 100 100 000 Old_age Always - 536
240 Head_Flying_Hours 0x0001 100 100 001 Pre-fail Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 35 -
# 2 Short offline Completed without error 00% 10 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
