Hi All,
OK I have started to use freenas in anger now and recommended it to be used in a few small businesses.. as part of this new hair brained scheme I decided to upgrade my personal system over the weekend with some bigger disks and then used ZFS replication to pull my data back...
Config I have is thus :
Build FreeNAS-9.2.1-RELEASE-x64 (bd35c86)
Platform AMD Turion(tm) II Neo N40L Dual-Core Processor
Memory
8042MB
HW is a an HP MS N40L , 8gb ram and 4 2tb internal disk and 1 2TB in a sata caddy.
a circa 2.7tb snapshot finished transferring to this unit over night to a dataset...
I checked the data over and all was fine except for it had put the data in a dir within a dir...
I ran a mv command to put the data in the root level of the data set and all was working fine until...
box hung up completely .... no ssh no gui shell.... no access to the disks.....
OK after 20 mins a three pin reboot was utilised and all has come back OK except for the messages log is filling up with
Feb 17 09:39:04 zestnasnew sshd[5622]: in openpam_check_error_code(): pam_sm_setcred(): unexpected return value 12
Any ideas ???
Memory
8042MB
Any ideas ???
