Advice on SMARTCTL Errors
mgkelly
Hi Guys
Been doing a lot of reading on here the last week or so and tried to do a fair bit of background prep. Thanks for all the good reading material very informative and helpful.
I have a HP Proliant Gen7
FreeNAS-8.3.2-RELEASE-x64 (r12686+70c2cb8)
AMD Turion(tm) II Neo N40L Dual-Core Processor
8GB Ram (non ECC)
and it has 4*2TB drives set up as a RAIDZ1.
This was setup for me by a friend about 3 years ago as an iScsi that I just connected to from my and used as a c5TB storage drive mainly for backup and media server. It has worked fine so I have left well enough alone havent upgraded the Freenas version or touched the discs.
A couple of weeks ago I got my first Amber alert in the web interface. I checked out zpool status, rebooted and it cleared and then seemed ok. However, I had a power cut which brought back another amber error this time seemingly more worrying "The volume RAIDZVolume status is UNKNOWN. One or more devices has experienced an unrecoverable error. An attempt was made to correct the error."
I read up on the SMARTCTL tests and have run several - I had "Current Pending Sectors"=2 which made me think the HD was starting to fail. I started a one time scrub (scrubs are scheduled monthly). After the scrub completed I got a message stating that it had fixed xxxKB in several hours but the errors were gone and everything sems fine once again.
However, I now am nervous and have backed up important files to external HD.
The ada0 device is the one that reported error and I would be grafeul one of you experts could take a look at the output and say whether I have cause to be concerned - all the obvious parts look ok in the report but it is still refering to several errors
Below is the out for all devices
smartctl -t long /dev/adaX
Edit --- Output posted in post below as I messed up the copy paste originally
As an aside ada1-3 smartctl output look totally fine to my uneducated eye, though after reading CyberJocks Hacking WD Greens(and Reds) with WDIDLE3.exe it seems like I should apply that to the Greens in my zpool? LCL 142k vs 1k of the Deskstars.
Appreciate any advice.
Thanks
mgkelly
Sorry - output didnt copy over correctly
root@freenas] ~# smartctl -a /dev/ada0
smartctl 5.43 2012-06-30 r3573 [FreeBSD 8.3-RELEASE-p10 amd64] (local build)
Copyright (C) 2002-12 by Bruce Allen, http://smartmontools.sourceforge.net
Model Family:	 Hitachi Deskstar 5K3000
Device Model:	 Hitachi HDS5C3020ALA632
Serial Number:	ML2220FA04U14E
LU WWN Device Id: 5 000cca 36ac22f78
Firmware Version: ML6OA800
User Capacity:	2,000,398,934,016 bytes [2.00 TB]
Sector Size:	  512 bytes logical/physical
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   8
ATA Standard is:  ATA-8-ACS revision 4
Local Time is:	Sat Jan  6 10:22:23 2018 PST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x84) Offline data collection activity
										was suspended by an interrupting command from host.
Self-test execution status:	  (   0) The previous self-test routine completed
										been run.
data collection:				(20419) seconds.
capabilities:					(0x5b) SMART execute Offline immediate.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   1) minutes.
Extended self-test routine
recommended polling time:		( 341) minutes.
SCT capabilities:			  (0x003d) SCT Status supported.
										SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x000b   100   100   016	Pre-fail  Always	   -	   0
  2 Throughput_Performance  0x0005   138   138   054	Pre-fail  Offline	  -	   88
  3 Spin_Up_Time			0x0007   135   135   024	Pre-fail  Always	   -	   408 (Average 404)
  4 Start_Stop_Count		0x0012   100   100   000	Old_age   Always	   -	   64
  5 Reallocated_Sector_Ct   0x0033   100   100   005	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x000b   100   100   067	Pre-fail  Always	   -	   0
  8 Seek_Time_Performance   0x0005   144   144   020	Pre-fail  Offline	  -	   30
  9 Power_On_Hours		  0x0012   095   095   000	Old_age   Always	   -	   36520
 10 Spin_Retry_Count		0x0013   100   100   060	Pre-fail  Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   62
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   1063
193 Load_Cycle_Count		0x0012   100   100   000	Old_age   Always	   -	   1063
194 Temperature_Celsius	 0x0002   193   193   000	Old_age   Always	   -	   31 (Min/Max 13/48)
196 Reallocated_Event_Count 0x0032   100   100   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0022   100   100   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0008   100   100   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x000a   200   200   000	Old_age   Always	   -	   0
SMART Error Log Version: 1
ATA Error Count: 10 (device log contains only the most recent five errors)
		CR = Command Register [HEX]
		FR = Features Register [HEX]
		ER = Error register [HEX]
		ST = Status register [HEX]
Error 10 occurred at disk power-on lifetime: 36313 hours (1513 days + 1 hours)
  ER ST SC SN CL CH DH
  40 51 41 7f bd 86 02  Error: UNC at LBA = 0x0286bd7f = 42384767
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  60 ab 28 6b be 86 40 00   1d+03:26:00.611  READ FPDMA QUEUED
  60 55 20 16 be 86 40 00   1d+03:26:00.611  READ FPDMA QUEUED
  60 56 18 c0 bd 86 40 00   1d+03:26:00.610  READ FPDMA QUEUED
  60 55 10 6b bd 86 40 00   1d+03:26:00.610  READ FPDMA QUEUED
  2f 00 01 10 00 00 00 00   1d+03:26:00.610  READ LOG EXT
Error 9 occurred at disk power-on lifetime: 36313 hours (1513 days + 1 hours)
  60 ab 10 6b be 86 40 00   1d+03:25:56.666  READ FPDMA QUEUED
  60 55 08 16 be 86 40 00   1d+03:25:56.666  READ FPDMA QUEUED
  60 56 00 c0 bd 86 40 00   1d+03:25:56.666  READ FPDMA QUEUED
  60 55 f8 6b bd 86 40 00   1d+03:25:56.666  READ FPDMA QUEUED
  2f 00 01 10 00 00 00 00   1d+03:25:56.665  READ LOG EXT
Error 8 occurred at disk power-on lifetime: 36313 hours (1513 days + 1 hours)
  60 ab f8 6b be 86 40 00   1d+03:25:52.721  READ FPDMA QUEUED
  60 55 f0 16 be 86 40 00   1d+03:25:52.721  READ FPDMA QUEUED
  60 56 e8 c0 bd 86 40 00   1d+03:25:52.721  READ FPDMA QUEUED
  60 55 e0 6b bd 86 40 00   1d+03:25:52.721  READ FPDMA QUEUED
  2f 00 01 10 00 00 00 00   1d+03:25:52.721  READ LOG EXT
Error 7 occurred at disk power-on lifetime: 36313 hours (1513 days + 1 hours)
  60 ab e0 6b be 86 40 00   1d+03:25:48.776  READ FPDMA QUEUED
  60 55 d8 16 be 86 40 00   1d+03:25:48.776  READ FPDMA QUEUED
  60 56 d0 c0 bd 86 40 00   1d+03:25:48.776  READ FPDMA QUEUED
  60 55 c8 6b bd 86 40 00   1d+03:25:48.776  READ FPDMA QUEUED
  2f 00 01 10 00 00 00 00   1d+03:25:48.776  READ LOG EXT
Error 6 occurred at disk power-on lifetime: 36313 hours (1513 days + 1 hours)
  60 ab c8 6b be 86 40 00   1d+03:25:44.832  READ FPDMA QUEUED
  60 55 c0 16 be 86 40 00   1d+03:25:44.830  READ FPDMA QUEUED
  60 56 b8 c0 bd 86 40 00   1d+03:25:44.830  READ FPDMA QUEUED
  60 55 b0 6b bd 86 40 00   1d+03:25:44.830  READ FPDMA QUEUED
  60 56 a8 15 bd 86 40 00   1d+03:25:44.830  READ FPDMA QUEUED
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline	Completed without error	   00%	 36505		 -
# 2  Extended offline	Completed without error	   00%	 36362		 -
# 3  Short offline	   Completed without error	   00%	 36333		 -
# 4  Extended offline	Aborted by host			   90%	 36333		 -
# 5  Extended offline	Completed without error	   00%	 36333		 -
# 6  Short offline	   Completed without error	   00%	 36323		 -
# 7  Short offline	   Completed without error	   00%	 36323		 -
# 8  Short offline	   Completed without error	   00%	 36323		 -
# 9  Extended offline	Aborted by host			   90%	 36323		 -
#10  Extended offline	Completed: read failure	   60%	 36303		 1384556751
#11  Extended offline	Aborted by host			   90%	 36302		 -
#12  Extended offline	Completed: read failure	   60%	 36301		 1384556751
2 of 2 failed self-tests are outdated by newer successful extended offline self-test # 1
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
[root@freenas] ~#
[root@freenas] ~#
[root@freenas] ~#
[root@freenas] ~# smartctl -a /dev/ada1
Serial Number:	ML2220FA08K67E
LU WWN Device Id: 5 000cca 36ac3e38a
ATA Version is:   8
Local Time is:	Sat Jan  6 10:22:27 2018 PST
Offline data collection status:  (0x82) Offline data collection activity
										was completed without error.
										been run.
data collection:				(22966) seconds.
										command.
										power-saving mode.
recommended polling time:		( 383) minutes.
  2 Throughput_Performance  0x0005   134   134   054	Pre-fail  Offline	  -	   103
  3 Spin_Up_Time			0x0007   134   134   024	Pre-fail  Always	   -	   410 (Average 410)
  4 Start_Stop_Count		0x0012   100   100   000	Old_age   Always	   -	   92
  9 Power_On_Hours		  0x0012   095   095   000	Old_age   Always	   -	   36613
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   85
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   1079
193 Load_Cycle_Count		0x0012   100   100   000	Old_age   Always	   -	   1079
194 Temperature_Celsius	 0x0002   193   193   000	Old_age   Always	   -	   31 (Min/Max 13/51)
No Errors Logged
# 1  Extended offline	Completed without error	   00%	 36599		 -
# 2  Extended offline	Completed without error	   00%	 36456		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
[root@freenas] ~#
[root@freenas] ~#
[root@freenas] ~# smartctl -a /dev/ada2
Device Model:	 WDC WD20EZRX-00D8PB0
Serial Number:	WD-WMC4M1288587
LU WWN Device Id: 5 0014ee 0ae53f23f
Firmware Version: 80.00A80
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Device is:		Not in smartctl database [for details use: -P showall]
ATA Version is:   8
ATA Standard is:  ACS-2 (revision not indicated)
Local Time is:	Sat Jan  6 10:22:32 2018 PST
										been run.
data collection:				(27120) seconds.
capabilities:					(0x7b) SMART execute Offline immediate.
										command.
										power-saving mode.
recommended polling time:		(   2) minutes.
recommended polling time:		( 274) minutes.
Conveyance self-test routine
recommended polling time:		(   5) minutes.
SCT capabilities:			  (0x7035) SCT Status supported.
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   0
  3 Spin_Up_Time			0x0027   176   174   021	Pre-fail  Always	   -	   4191
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   49
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   200   200   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   051   051   000	Old_age   Always	   -	   36357
 10 Spin_Retry_Count		0x0032   100   253   000	Old_age   Always	   -	   0
 11 Calibration_Retry_Count 0x0032   100   253   000	Old_age   Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   49
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   29
193 Load_Cycle_Count		0x0032   153   153   000	Old_age   Always	   -	   142313
194 Temperature_Celsius	 0x0022   119   108   000	Old_age   Always	   -	   28
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   200   200   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
200 Multi_Zone_Error_Rate   0x0008   200   200   000	Old_age   Offline	  -	   0
No Errors Logged
# 1  Extended offline	Completed without error	   00%	 36342		 -
# 2  Extended offline	Completed without error	   00%	 36199		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
[root@freenas] ~#
[root@freenas] ~#
[root@freenas] ~# smartctl -a /dev/ada3
Serial Number:	WD-WMC4M1235153
LU WWN Device Id: 5 0014ee 003a9277d
ATA Version is:   8
Local Time is:	Sat Jan  6 10:22:35 2018 PST
										been run.
data collection:				(25980) seconds.
										command.
										power-saving mode.
recommended polling time:		( 263) minutes.
  3 Spin_Up_Time			0x0027   171   170   021	Pre-fail  Always	   -	   4416
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   48
  9 Power_On_Hours		  0x0032   051   051   000	Old_age   Always	   -	   36360
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   48
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   28
193 Load_Cycle_Count		0x0032   154   154   000	Old_age   Always	   -	   140165
No Errors Logged
# 1  Extended offline	Completed without error	   00%	 36346		 -
# 2  Short offline	   Completed without error	   00%	 36209		 -
# 3  Extended offline	Completed without error	   00%	 36202		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
[root@freenas] ~#
Jailer
Not strong, but bad
ada0 is toast. You have several read errors and it's failed smart tests. You also are not conducting periodic smart test on all your drives and you should be.
mgkelly
I guess thats what I was worried about but the "failures are outdated" and Scrub seemed to fixed it made me think maybe I was ok after all given that the long test is coming back 100% now and no read errors being reported now.
Thanks for the reply!
