Option to disable moused?
I think that moused_ums0_enable="NO" in a sysctl will disable it just based on a 2 minute Google search. No promises though. :P
I believe I prevented moused from consuming the 15kbytes of RAM it was using by setting USB legacy mouse support = DISABLED in my motherboard BIOS. Many motherboards will emulate a USB mouse even if one isn't attached if the setting is enabled.
William Grzybowski
No loader nor sysctl can do that.
You could maybe do that editing /conf/base/etc/defaults/rc.conf
moused_nondefault_enable="NO" , or something
