spotcatbug
 - Nov 6, 2017
I had a working OpenVPN iocage jail. It stopped working. Unfortunately, I hadn't used the VPN in a while (a couple of months), so I don't know exactly when it stopped working - that is, I'm not sure what I did to make it break. I've been spending a lot of time on this. I need help! Please.
What does "stopped working" mean? I couldn't connect the VPN on my iPhone (attempting to connect to the server timed-out). I discovered that the jail had no networking. It failed the ping test. After much fiddling ping works and I can connect to the server from the client (my iPhone on the cell network, will connect to the OpenVPN server on my LAN). However, even though the connection looks good and established, I can't connect to anything on my LAN through the VPN.
I remember having this issue when I first set-up the jail. Same symptoms: connection looked good but no traffic through the VPN. Turned out I needed a static route on my router to send the VPN subnet (10.8.0.0/24) traffic to the OpenVPN server (10.0.1.52/24). I added that static route to my home router and that fixed it. Not this time, though. The static route is there still. I tried removing it and putting it back, in case the router was having an issue - no change.
I'm guessing there's some other networking issue at play, but I'm not good enough at this to know what that is. I'm hoping somebody looking at my ifconfig listings might see a problem or have ideas.
host ifconfig:
OpenVPN jail ifconfig:
Anything else I should supply?
Thanks for any help.
host ifconfig:
igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=b8<VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM>
	ether d0:50:99:c2:f0:1f
	hwaddr d0:50:99:c2:f0:1f
	media: Ethernet autoselect (1000baseT <full-duplex>)
	status: active
em0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=98<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM>
	hwaddr d0:50:99:c2:f0:20
	status: active
	options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
	inet6 ::1 prefixlen 128
	inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
	groups: lo
lagg0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	inet 10.0.1.114 netmask 0xffffff00 broadcast 10.0.1.255
	inet 10.0.1.63 netmask 0xffffff00 broadcast 10.0.1.255
	status: active
	groups: lagg
	laggproto loadbalance lagghash l2,l3,l4
	laggport: igb0 flags=4<ACTIVE>
	laggport: em0 flags=4<ACTIVE>
	ether 02:81:c5:8a:b2:00
	nd6 options=1<PERFORMNUD>
	groups: bridge
bridge1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
	ether 02:81:c5:8a:b2:01
	groups: bridge
	member: vnet0:5 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 6 priority 128 path cost 2000
	member: epair2a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 9 priority 128 path cost 2000
	member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 8 priority 128 path cost 2000
	member: lagg0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 4 priority 128 path cost 10000
epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=8<VLAN_MTU>
	ether 02:9d:50:00:08:0a
	hwaddr 02:9d:50:00:08:0a
	status: active
	groups: epair
epair2a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=8<VLAN_MTU>
	ether 02:9d:50:00:09:0a
	hwaddr 02:9d:50:00:09:0a
	status: active
	groups: epair
vnet0:5: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	description: associated with jail: OpenVPN
	options=8<VLAN_MTU>
	ether 02:ff:60:9b:c8:7f
	hwaddr 02:9d:50:00:06:0a
	status: active
	groups: epair
	inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
	groups: lo
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=8<VLAN_MTU>
	ether 02:ff:60:9b:c8:80
	hwaddr 02:9d:a0:00:0a:0b
	inet 10.0.1.52 netmask 0xffffff00 broadcast 10.0.1.255
	status: active
	groups: epair
tun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> metric 0 mtu 1500
	options=80000<LINKSTATE>
	inet 10.8.0.1 --> 10.8.0.2  netmask 0xffffffff
	groups: tun
