OpenVPN fails in jail with libdl.so.1 not found error
laskeyp
Newly created FreeNAS 11.1-U6 standard jail. Updated and upgraded everything. Installed OPENVPN from pkg. openvpn fails to execute with error:
Shared object "libdl.so.1" not found, required by "openvpn". All install guides just assume that this will not occur. Cannot determine how to install this object. I have see that this error also affects Python, BASH ans possible others. Can anyone tell me how to get past this deficiency?
Thank you!
krazos
Same issue here. Can't run Ruby or anything else since it requires libdl.so.1
Temporary solution:
Copied libdl.so and libdl.so.1 from /usr/lib/ in freenas root and pasted into my jails /usr/lib and now I can run Ruby and everything else.
endianx
Experiencing the same issue in a vanilla jail.
pkg install python27-2.7.15
Gets me...
root@sabnzbd:/usr/lib # python2.7
Shared object "libdl.so.1" not found, required by "python2.7"
Looking at ldd...
root@sabnzbd:/usr/lib # ldd /usr/local/bin/python2.7
/usr/local/bin/python2.7:
libthr.so.3 => /lib/libthr.so.3 (0x800821000)
libpython2.7.so.1 => /usr/local/lib/libpython2.7.so.1 (0x800a48000)
libdl.so.1 => not found (0)
libintl.so.8 => /usr/local/lib/libintl.so.8 (0x800e31000)
libutil.so.9 => /lib/libutil.so.9 (0x80103c000)
libm.so.5 => /lib/libm.so.5 (0x80124f000)
libc.so.7 => /lib/libc.so.7 (0x80147a000)
But if I install the sabnzbd plugin from wUI python runs fine in the jail and ldd says:
root@sabnzbd_1:/ # ldd /usr/local/bin/python2.7
libintl.so.8 => /usr/local/lib/libintl.so.8 (0x800e21000)
libutil.so.9 => /lib/libutil.so.9 (0x80102b000)
libm.so.5 => /lib/libm.so.5 (0x80123e000)
libc.so.7 => /lib/libc.so.7 (0x801469000)
Anyone have any ideas?
Scharbag
It looks as though given FreeBSD 11.1 is no longer supported, that the package infrastructure is different and is calling for some scruff that does not yet exist in 11.1. <-- this was edited as the next post points out the difference properly.
Here is where I found some info.
Timing is terrible as I was just trying to revise some scripts to get ready for 11.2... Booo.
Kadaki
According to that bug, libdl is a new library in 11.2 and the packages are failing because they are built linking to it. See also https://reviews.freebsd.org/D11504.
I was able to replicate krazos' fix of copying the libdl files from 11.2 to the jail's /usr/lib (although I used /usr/local/lib). It made python work, at least, but since libdl is essentially an alias for libc's dl* functions, I suspect it should work the same for the other packages.
Pancakes
As a temporary fix, inside your jail
vi /etc/pkg/FreeBSD.conf
and change the url line to read
  url: "pkg+http://pkg.FreeBSD.org/${ABI}/release_2",
release_2 was frozen at 2018-Jun-05, which is before libdl.so.1 was added.
You will probably need to force reinstall your installed packages to get things back to stable.
Scharbag
No luck with this. I make the change above, reboot the jail and run:
pkg update -f
pkg upgrade -f
This results in the following again:
root@Media:/ # python2.7
Not sure if there is something that I am missing here. Thanks for the help though. Might just have to wait until 11.2 actually gets released.
Pancakes
pkg update -f
pkg upgrade -f
Very odd. Works for me.
[root@plex /]# pkg update -f
Updating FreeBSD repository catalogue...
[plex] Fetching meta.txz: 100%	944 B   0.9kB/s	00:01
[plex] Fetching packagesite.txz: 100%	6 MiB   6.4MB/s	00:01
Processing entries: 100%
FreeBSD repository update completed. 31153 packages processed.
All repositories are up to date.
[root@plex /]# pkg upgrade
FreeBSD repository is up to date.
Checking for upgrades (0 candidates): 100%
Processing candidates (0 candidates): 100%
Checking integrity... done (0 conflicting)
Your packages are up to date.
[root@plex /]# pkg info python
python-2.7_3,2
Version		: 2.7_3,2
Installed on   : Sun Oct  7 15:47:44 2018 PDT
Origin		 : lang/python
Architecture   : FreeBSD:11:*
Prefix		 : /usr/local
Categories	 : python lang ipv6
Licenses	   :
Maintainer	 : python@FreeBSD.org
WWW			: http://www.python.org/
Comment		: "meta-port" for the default version of Python interpreter
Annotations	:
repo_type	  : binary
repository	 : FreeBSD
Flat size	  : 38.0B
Description	:
Python is an interpreted object-oriented programming language, and is
often compared to Tcl, Perl or Scheme.
This is a meta port to the Python interpreter and provides symbolic links
to bin/python, bin/pydoc, bin/idle and so on to allow compatibility with
version agnostic python scripts.
WWW: http://www.python.org/
[root@plex /]# ldd /usr/local/bin/python2.7
libthr.so.3 => /lib/libthr.so.3 (0x800822000)
libpython2.7.so.1 => /usr/local/lib/libpython2.7.so.1 (0x800a4a000)
libintl.so.8 => /usr/local/lib/libintl.so.8 (0x800e29000)
libutil.so.9 => /lib/libutil.so.9 (0x801034000)
libm.so.5 => /lib/libm.so.5 (0x801248000)
libc.so.7 => /lib/libc.so.7 (0x801473000)
[root@plex /]# sha256 /usr/local/bin/python2.7
SHA256 (/usr/local/bin/python2.7) = fe335a3465231075fe2a9bdb5c57dcebe34e8becb6f17b65402aed5694442dce
[root@plex /]# uname -KU
1101505 1101001
You might try
vi /usr/local/etc/pkg.conf
set OSVERSION
OSVERSION = 1101001
and then retry the forced reinstall... or just sit it out and wait for a fix from upstream :)
Locci
pkg update -f
pkg upgrade -f
Editing /usr/local/etc/pkg/repos/FreeBSD.conf instead made it download the old release for me.
Got openvpn working atleast :)
Scharbag
Spanks!!
XTREEMMAK
Ohh my thank you! I'm finally able to continue working on migrating my jails again :)
I did both just to be safe:
First do an install for pkg in the iocage, then
ee /usr/local/etc/pkg.conf
then on first line add
set OSVERSION = 1101001
then
ee /etc/pkg/FreeBSD.conf
then change quarterly to release aka from this:
url: "pkg+http://pkg.FreeBSD.org/${ABI}/quarterly",
to this:
Once all is good hit that good ol,
pkg update -f
pkg upgrade -f
And you should be good :)
PatarNoster
Temporary solution:
Hey mate, might be a dumb question but how do you get to the freenas root? to get those files?
PatarNoster
then
to this:
pkg update -f
pkg upgrade -f
I have tried this 3 times now, still no go.
could you screen cap how to add the first line?
just not sure what i am missing....gah
