Looking through the changes in the latest stable release, I saw some notes on a newer version of Samba and VirtualBox jails being added and I thought I'd give it a try.
I did the rutine upgrade from 9.2.1.5 to 9.2.1.6 without problems, then navigated to Jails, and went ahead with adding a Ubuntu jail into the default location, which was (supposed to be) a folder where I have the single share with all my data. Then I navigated through the share to see what was being written there, and to my surprise/horror, all the other data was gone. In that folder there was only the "jails" folder.
I the logged on via ssh and issued a "zfs list" with the following result.
My data was in that /mnt/matrice1/backups folder, but as you can see, there are almost 3.5TB allocated to something that didn't show up, even in "ls" issued in a root console.
I then read in another thread here about unmounting and tried to issue a "zfs umount /mnt/matrice1/backups/jails" which failed, saying that the resource was in use. I deleted the test1 jail I had just created and then procedeed to unmount /mnt/matrice1/backups/jails/.warden-template-ubuntu-13.04, then /mnt/matrice1/backups/jails and finally /mnt/matrice1/backups. This did the trick! I now have my files back. I wonder what happens when I reboot this machine, ... do I have my files back or do I have to do the unmounts manualy every time?
So, for a simple case, where you only create one share, no separate datasets, the default location for jails is right there in the same path as all your data, and just fiddling with the Jails menu, thinking the defaults are safe, can get all your data unaccessible in an instant. There really should be some warnings or the default behavior changed to create a separate dataset that wouldn't overlap with anything user-created.
Did I do anything wrong?
NAME USED AVAIL REFER MOUNTPOINT matrice1 3.48T 1.85T 3.48T /mnt/matrice1 matrice1/.system 6.61M 1.85T 234K /mnt/matrice1/.system matrice1/.system/cores 192K 1.85T 192K /mnt/matrice1/.system/cores matrice1/.system/rrd 192K 1.85T 192K /mnt/matrice1/.system/rrd matrice1/.system/samba4 3.83M 1.85T 3.83M /mnt/matrice1/.system/samba4 matrice1/.system/syslog 2.17M 1.85T 2.17M /mnt/matrice1/.system/syslog matrice1/backups 884M 1.85T 202K /mnt/matrice1/backups matrice1/backups/jails 884M 1.85T 277K /mnt/matrice1/backups/jails matrice1/backups/jails/.warden-template-ubuntu-13.04 878M 1.85T 878M /mnt/matrice1/backups/jails/.warden-template-ubuntu-13.04 matrice1/backups/jails/test1 5.96M 1.85T 883M /mnt/matrice1/backups/jails/test1
