Hazar
- Dec 9, 2016
I moved my .system dataset (and swapfile) to an internal USB drive (named
On my first
The system is still working but as you can see it is a ticking bomb. And regular stream of writing to
How can I proceed to change this USB drive? Is there any instructions or guidance to replace drives that contains
I have a FreeNAS config backup but I think .system dataset contains much more of than. Do I need to try mounting my system dataset somewhere and back it up?
Note: I don't store my jails in this drive.
System:
FreeNAS-9.10.2-U3 (e1497f269)
HP Microserver G8 with 12G RAM
Thanks in advance.
usbdrive
) 7 months ago. Today, my scheduled scrub alerted me that I have a checksum error on that USB drive.On my first
zpool status -v usbdrive
it only mentioned checksum errors and no data was corrupted. However, after I issued a zpool scrub usbdrive
it says I have a corrupted swapfile. While I'm using 0 bytes of swap, I issued a swapoff
(because if it ever swaps to it and tries to read back, probably the next thing I see is a kernel panic). Further iterations of scrub resulted in differing amounts of cksum errors; which clearly shows the USB drive is on its highway to hell. Now it shows that I have an unrecoverable error at usbdrive:<0x8>
. I stopped at this point.The system is still working but as you can see it is a ticking bomb. And regular stream of writing to
.system
dataset is not helping either.How can I proceed to change this USB drive? Is there any instructions or guidance to replace drives that contains
.system
dataset?I have a FreeNAS config backup but I think .system dataset contains much more of than. Do I need to try mounting my system dataset somewhere and back it up?
# zfs list -r usbdrive NAME USED AVAIL REFER MOUNTPOINT usbdrive 870M 2.74G 36.5M /mnt/usbdrive usbdrive/.system 421M 2.74G 402M legacy usbdrive/.system/configs-810048d7feed436fae88f4409435135f 15.1M 2.74G 15.1M legacy usbdrive/.system/cores 722K 2.74G 722K legacy usbdrive/.system/rrd-810048d7feed436fae88f4409435135f 19K 2.74G 19K legacy usbdrive/.system/samba4 91K 2.74G 91K legacy usbdrive/.system/syslog-810048d7feed436fae88f4409435135f 2.62M 2.74G 2.62M legacy usbdrive/jails 411M 2.74G 21K /mnt/usbdrive/jails usbdrive/jails/.warden-template-pluginjail 411M 2.74G 409M /mnt/usbdrive/jails/.warden-template-pluginjail
System:
Thanks in advance.
