one or more devices has experienced an error..
daeda
Hi guys,
I gues this topic has appeared quite often up to now. I went through a few threads concerning that problem but couldn't really get something out of it. I'm using ECC RAM but haven't tested it yet, since I cannot boot into memtest because the board doesn't want to boot from usb and I don't know why. The file enclosed contains the results of smartctl -a /dev/adaX from 0-5.
So I start posting the logs and hope someone sees more in them than I'm able to. I hope someone can help here. If more logs are needed I will gladly provide them.
Here is as requested my setup:
  • FreeNAS-11.1-RELEASE
  • ASRock C2550D4I Mainboard - socked - DDR3 RAM - MI
  • 450 Watt Corsair SF Series SF450 Modular 80+ Gold
  • 16GB (2x 8192MB) Kingston ValueRAM DDR3-1333 ECC DIMM CL9-9-9 Dual Kit
  • 1x 250GB Samsung 850 Evo 2.5" (6.4cm) SATA 6Gb/s TLC Toggle (MZ-75E250B/EU)
  • 2x 3000GB WD Red WD30EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
  • 3x 3000GB Seagate IronWolf ST3000VN007 5.900U/min 64MB 3.5" (8.9cm) SATA 6Gb/s
The system runs on the SSD.
Thanks
zpool status -v
  pool: Platte
 state: ONLINE
   corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
   entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: scrub repaired 0 in 0 days 22:58:19 with 1 errors on Mon Dec 25 02:58:21 2017
   NAME												STATE	 READ WRITE CKSUM
   Platte											  ONLINE	   0	 0	 0
	 raidz1-0										  ONLINE	   0	 0	 0
	   gptid/584f58df-a993-11e7-84b0-d05099c2bce3.eli  ONLINE	   0	 0	 0
	   gptid/59107f79-a993-11e7-84b0-d05099c2bce3.eli  ONLINE	   0	 0	 0
	   gptid/5a439a95-a993-11e7-84b0-d05099c2bce3.eli  ONLINE	   0	 0	 0
	   gptid/5b6d528e-a993-11e7-84b0-d05099c2bce3.eli  ONLINE	   0	 0	 0
	   gptid/5c27ce56-a993-11e7-84b0-d05099c2bce3.eli  ONLINE	   0	 0	 0
		<0x3af>:<0x6e1f>
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0 days 00:00:05 with 0 errors on Sun Dec 24 03:45:06 2017
   freenas-boot  ONLINE	   0	 0	 0
	 ada4p2	ONLINE	   0	 0	 0
errors: No known data errors
  • smartctl.txt
BigDave
FreeNAS Enthusiast
the board
It will be wonderful if you can provide the details of your hardware.
Please read and follow the Forum Rules (there is a link at the top of each
page in the forum).
Please read my signature for an explanation as to the reasons for requesting this information.
We look forward to helping you once the requested information has been provided by you.
BigDave
FreeNAS Enthusiast
Your smart data shows no testing (long or short), so lets start there. Please run a long test for each
of the five drives in your pool and post the full (non-edited) results in code tags for each drive.
daeda
Ok I scheduled a short smart test for every night at 2 am. How should I synchronize this with scrubbing and snapshotting. Is there a best practice? Doesn't smart interefere with the scrubbing and snapshotting?
Jailer
Not strong, but bad
No. You should also schedule long test on all your drives as well at least once every other week.
BigDave
FreeNAS Enthusiast
I'm thinking that I must be clearer with my request. We are trying to find the reason for an error on your machine.
I would not concern myself at this time with a testing schedule, instead I would set up a LONG test on each one of
your drives right now. When those tests are done, post the entire content of the readout for each drive here.
Please post the output in code tags.
What part of "run a long test for each drive" sounded like "schedule a short test for later for each drive"?
daeda
I focused too much on the the short test part, that I overread the rest.
So here are the logs of my smart tests
smartctl -a /dev/ada0
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:	 Seagate IronWolf
Device Model:	 ST3000VN007-2E4166
Serial Number:	Z6A0Z4JV
LU WWN Device Id: 5 000c50 0a3c3202c
Firmware Version: SC60
User Capacity:	3,000,592,982,016 bytes [3.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	5900 rpm
Form Factor:	  3.5 inches
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Wed Jan  3 08:30:37 2018 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82)   Offline data collection activity
				   was completed without error.
Self-test execution status:	  (   0)   The previous self-test routine completed
				   been run.
data collection:		(   97) seconds.
capabilities:			 (0x7b) SMART execute Offline immediate.
				   command.
				   Self-test supported.
SMART capabilities:			(0x0003)   Saves SMART data before entering
				   power-saving mode.
Error logging capability:		(0x01)   Error logging supported.
Short self-test routine
recommended polling time:	 (   1) minutes.
Extended self-test routine
recommended polling time:	 ( 380) minutes.
Conveyance self-test routine
recommended polling time:	 (   2) minutes.
SCT capabilities:		   (0x10bd)   SCT Status supported.
				   SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x000f   118   099   006	Pre-fail  Always	   -	   173816800
  3 Spin_Up_Time			0x0003   094   094   000	Pre-fail  Always	   -	   0
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   27
  5 Reallocated_Sector_Ct   0x0033   100   100   010	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x000f   078   060   030	Pre-fail  Always	   -	   71101162
  9 Power_On_Hours		  0x0032   098   098   000	Old_age   Always	   -	   2152
 10 Spin_Retry_Count		0x0013   100   100   097	Pre-fail  Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   27
184 End-to-End_Error		0x0032   100   100   099	Old_age   Always	   -	   0
187 Reported_Uncorrect	  0x0032   100   100   000	Old_age   Always	   -	   0
188 Command_Timeout		 0x0032   100   100   000	Old_age   Always	   -	   0
189 High_Fly_Writes		 0x003a   091   091   000	Old_age   Always	   -	   9
190 Airflow_Temperature_Cel 0x0022   061   053   045	Old_age   Always	   -	   39 (Min/Max 37/44)
191 G-Sense_Error_Rate	  0x0032   100   100   000	Old_age   Always	   -	   0
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   18
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   31
194 Temperature_Celsius	 0x0022   039   047   000	Old_age   Always	   -	   39 (0 21 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0010   100   100   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x003e   200   200   000	Old_age   Always	   -	   0
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed without error	   00%	  2146		 -
# 2  Short offline	   Completed without error	   00%	  2122		 -
# 3  Extended offline	Completed without error	   00%	  2107		 -
# 4  Short offline	   Completed without error	   00%	  2074		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
smartctl -a /dev/ada1
Serial Number:	Z6A0Z5DD
LU WWN Device Id: 5 000c50 0a3c30c18
Local Time is:	Wed Jan  3 08:30:47 2018 CET
				   been run.
data collection:		(  107) seconds.
				   command.
				   power-saving mode.
recommended polling time:	 ( 384) minutes.
  1 Raw_Read_Error_Rate	 0x000f   115   099   006	Pre-fail  Always	   -	   98218616
  7 Seek_Error_Rate		 0x000f   078   060   030	Pre-fail  Always	   -	   83787432
  9 Power_On_Hours		  0x0032   098   098   000	Old_age   Always	   -	   2153
189 High_Fly_Writes		 0x003a   053   053   000	Old_age   Always	   -	   47
190 Airflow_Temperature_Cel 0x0022   063   052   045	Old_age   Always	   -	   37 (Min/Max 36/43)
194 Temperature_Celsius	 0x0022   037   048   000	Old_age   Always	   -	   37 (0 21 0 0 0)
No Errors Logged
# 2  Short offline	   Completed without error	   00%	  2123		 -
# 3  Extended offline	Completed without error	   00%	  2109		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
smartctl -a /dev/ada2
Model Family:	 Western Digital Red
Device Model:	 WDC WD30EFRX-68EUZN0
Serial Number:	WD-WCC4N2RZH1VA
LU WWN Device Id: 5 0014ee 20eb6f571
Firmware Version: 82.00A82
Rotation Rate:	5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Wed Jan  3 08:30:53 2018 CET
Offline data collection status:  (0x00)   Offline data collection activity
				   was never started.
				   been run.
data collection:		(41460) seconds.
				   command.
				   power-saving mode.
recommended polling time:	 ( 416) minutes.
recommended polling time:	 (   5) minutes.
SCT capabilities:		   (0x703d)   SCT Status supported.
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   0
  3 Spin_Up_Time			0x0027   183   179   021	Pre-fail  Always	   -	   5850
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   27
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   200   200   000	Old_age   Always	   -	   0
 10 Spin_Retry_Count		0x0032   100   253   000	Old_age   Always	   -	   0
 11 Calibration_Retry_Count 0x0032   100   253   000	Old_age   Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   27
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   17
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   92
194 Temperature_Celsius	 0x0022   118   108   000	Old_age   Always	   -	   32
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   100   253   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
200 Multi_Zone_Error_Rate   0x0008   200   200   000	Old_age   Offline	  -	   0
No Errors Logged
# 1  Extended offline	Completed without error	   00%	  2146		 -
# 2  Short offline	   Interrupted (host reset)	  10%	  2138		 -
# 3  Extended offline	Completed without error	   00%	  2120		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
smartctl -a /dev/ada3
Serial Number:	WD-WCC4N2RZHTUH
LU WWN Device Id: 5 0014ee 20eb7c06b
Local Time is:	Wed Jan  3 08:30:58 2018 CET
				   was never started.
				   been run.
data collection:		(40020) seconds.
				   command.
				   power-saving mode.
recommended polling time:	 ( 401) minutes.
  3 Spin_Up_Time			0x0027   182   178   021	Pre-fail  Always	   -	   5891
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   102
No Errors Logged
# 2  Extended offline	Interrupted (host reset)	  10%	  2138		 -
# 3  Short offline	   Completed without error	   00%	  2074		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
smartctl -a /dev/ada4
Model Family:	 Samsung based SSDs
Device Model:	 Samsung SSD 850 EVO 250GB
Serial Number:	S3R0NF0J870422F
LU WWN Device Id: 5 002538 d4229195c
Firmware Version: EMT03B6Q
User Capacity:	250,059,350,016 bytes [250 GB]
Rotation Rate:	Solid State Device
Form Factor:	  2.5 inches
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4c
Local Time is:	Wed Jan  3 08:31:04 2018 CET
				   was never started.
				   been run.
data collection:		(	0) seconds.
capabilities:			 (0x53) SMART execute Offline immediate.
				   command.
				   No Offline surface scan supported.
				   power-saving mode.
recommended polling time:	 ( 133) minutes.
SCT capabilities:		   (0x003d)   SCT Status supported.
  9 Power_On_Hours		  0x0032   099   099   000	Old_age   Always	   -	   2154
 12 Power_Cycle_Count	   0x0032   099   099   000	Old_age   Always	   -	   28
177 Wear_Leveling_Count	 0x0013   100   100   000	Pre-fail  Always	   -	   0
179 Used_Rsvd_Blk_Cnt_Tot   0x0013   100   100   010	Pre-fail  Always	   -	   0
181 Program_Fail_Cnt_Total  0x0032   100   100   010	Old_age   Always	   -	   0
182 Erase_Fail_Count_Total  0x0032   100   100   010	Old_age   Always	   -	   0
183 Runtime_Bad_Block	   0x0013   100   100   010	Pre-fail  Always	   -	   0
187 Uncorrectable_Error_Cnt 0x0032   100   100   000	Old_age   Always	   -	   0
190 Airflow_Temperature_Cel 0x0032   071   064   000	Old_age   Always	   -	   29
195 ECC_Error_Rate		  0x001a   200   200   000	Old_age   Always	   -	   0
199 CRC_Error_Count		 0x003e   100   100   000	Old_age   Always	   -	   0
235 POR_Recovery_Count	  0x0012   099   099   000	Old_age   Always	   -	   19
241 Total_LBAs_Written	  0x0032   099   099   000	Old_age   Always	   -	   9432958
No Errors Logged
# 1  Short offline	   Completed without error	   00%	  2148		 -
# 2  Short offline	   Completed without error	   00%	  2124		 -
# 3  Short offline	   Completed without error	   00%	  2100		 -
# 4  Extended offline	Completed without error	   00%	  2086		 -
# 5  Short offline	   Completed without error	   00%	  2076		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
  255		0	65535  Read_scanning was never started
smartctl -a /dev/ada5
Serial Number:	Z6A0Y8WT
LU WWN Device Id: 5 000c50 0a3b393d2
Local Time is:	Wed Jan  3 08:31:08 2018 CET
				   been run.
				   command.
				   power-saving mode.
recommended polling time:	 ( 386) minutes.
  1 Raw_Read_Error_Rate	 0x000f   114   099   006	Pre-fail  Always	   -	   80083248
  7 Seek_Error_Rate		 0x000f   078   060   030	Pre-fail  Always	   -	   73247228
189 High_Fly_Writes		 0x003a   090   090   000	Old_age   Always	   -	   10
190 Airflow_Temperature_Cel 0x0022   063   056   045	Old_age   Always	   -	   37 (Min/Max 36/42)
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   19
194 Temperature_Celsius	 0x0022   037   044   000	Old_age   Always	   -	   37 (0 21 0 0 0)
No Errors Logged
# 1  Short offline	   Completed without error	   00%	  2147		 -
# 4  Short offline	   Completed without error	   00%	  2075		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
daeda
Has anybody advice? At least how to get rid of the warning if it is not a problem.
