Offsite cloud storage backups
Lightlazer
I am struggling to find the best cloud storage backup scheme for my office Freenas. It is ~15 TB three zpool 12 HD server with video recordings and multimedia mostly. Up until now my backup scheme was manually attaching a pool of three usb external drives and have a recursive cp done monthly (each ~5TB pool takes around 2 days).
After a small incident with an outdated backups we want to switch to a safer backup scheme. We are considering something like Amazon, Google Drive, dropbox... because lately their pricing has gone really low, some even offer unlimited storage for as low as 60€/month. The idea is the server to periodically sync its data to differential or incremental backups.
I am a bit lost on the topic of online backups so I ask for advice.
Cheers.
Pheran
Take a look at Crashplan, there's a FreeNAS plugin that integrates with it. The only issue is that I don't know how the performance would be from Spain. I see there's some sort of European Crashplan called Ceejay, but I don't know if the FreeNAS plugin works with that or not.
Vincèn
Crashplan is not really usable on FreeNAS for large volume of data, upload is crazy slow (only 1/2M/s max) unless I have a gigabit connection to Internet :(
jgreco
Resident Grinch
I know some people like to use a Windows VM and install the Backblaze (or other random backup provider) software.
Spacemarine
What is that supposed to mean? I'm getting 2 Mbit/s, I read about other people getting about the same, so that seems to be the "normal" upload speed for crashplan.
Why do you think the upload will get faster, if you have a faster internet connection, even if crashplan can't my out a slow connection?
jgreco
Resident Grinch
Well, the fundamental problem is that if you have a terabyte of stuff to upload, and you have 2Mbps upstream, it might take a month or two to upload that much content.
Vincèn
and worse when you have around 20To of data to backup ! Right now I went to using Insync to synchronise to my Unlimited Google Drive ;)
