Miniwehats
- Feb 29, 2012
So went to replace a drive today and I offlined the wrong drive in the GUI so I went to use the replace button and just let it grab that same drive back in and probably resliver but it threw this error.
can anyone help me with that syntax?
so I guess it just sees it already so I thought I would try to Online the drive in the CLI and I get this.
I am pretty sure the drive is not failed as none have shown failed before. It could be failed so I can pull it later and test it. Got any ideas how to make this work? Do i need to zero the drive first and put it back in? I am a nub the last few days I swear I keep doing things wrong.
ification, use '-f' to override the following errors:, /dev/gptid/39c5789e-5c04-11e2-a059-bc5ff4365648 is part of active pool 'Vol0', "]
[root@freenas] ~# zpool online Vol0 14713318185702787415 warning: device '14713318185702787415' onlined, but remains in faulted state use 'zpool replace' to replace devices that are no longer present
[root@freenas] ~# glabel status
Name Status Components
gptid/9ebf2708-5b6d-11e2-9efd-bc5ff4365648 N/A ada0p2
gptid/338243b8-e7fc-11e1-8afc-00045fb309e8 N/A ada1p2
gptid/342046fb-e7fc-11e1-8afc-00045fb309e8 N/A ada2p2
gptid/52e8cd24-e7fc-11e1-8afc-00045fb309e8 N/A ada3p2
gptid/33c3355c-e7fc-11e1-8afc-00045fb309e8 N/A ada5p2
gptid/7b92c455-2bca-11e2-ad71-00045fb309e8 N/A ada6p2
gptid/263683e3-5ab5-11e2-a20c-bc5ff4365648 N/A ada7p2
ufs/FreeNASs3 N/A da0s3
ufs/FreeNASs4 N/A da0s4
ufs/FreeNASs1a N/A da0s1a
gptid/39c5789e-5c04-11e2-a059-bc5ff4365648 N/A ada4p2
gptid/39b44479-5c04-11e2-a059-bc5ff4365648 N/A ada4p1
