Anaerin
- Jun 20, 2019
I have a linux server set up with NUT to share the current UPS status, which is working just fine in the attached pfSense router. But when I use the GUI to set it up under FreeNAS I get the following error in the syslog:
Checking the folder, it contains:
The settings appear to be all correct, so for some reason the web UI is not generating the correct conf files for NUT.
Is there anything I can do to fix this?
Jun 20 21:17:43 freenas root: /usr/local/etc/rc.d/nut: WARNING: /usr/local/etc/nut/ups.conf is not readable.
[anaerin@freenas /usr/local/etc/nut]$ ls -al total 14 drwxr-xr-x 2 root wheel 128 Jun 20 21:17 . drwxr-xr-x 34 root wheel 5824 Jun 20 21:17 .. -r--r----- 1 root uucp 472 Jun 20 21:17 upsmon.conf -r--r----- 1 root uucp 473 Jun 20 21:17 upssched.conf
