NUT Configuration as SLAVE
ChrisChros
I have a APC Smart-UPS witch is connected via USB to my homeserver with CentOS. In CentOS I have the APCUPSD daemon installed to get all the datas from the UPS.
Now I want to setup FreeNAS as SLAVE to get also the datas from my homeserver.
As remote host I insert the IP from my homeserver. Under port I insert which I have setup in the APCUPSD on my homeserver.
Unfortunately the NAS don't get any datas from the server.
upsc ups@<IP homeserver>: Port will receive "Error: Write error: Broken pipe"
Can anybody help me?
Thanks for your support.
Chris
m0nkey_
FreeNAS uses NUT. In order to make this work, you would need to run NUT on your CentOS server.
ChrisChros
Got it to work.
I had to configure not as SLAVE rather as MASTER.
Driver I choosed "APC ups 3 (various) APCUPSD-controlled devices (apcupsd-ups)" and as Port I wrote in the IP:Port of the APCUPSD-Server.
With this configuration I am able to connect to my APCUPSD-Server and get the informations.
