Notifications won't go away
bqz
Hi all!
This is a minor problem I'm having.
I would like to remove a couple of notifications that are permanently showing (more than one year).
Is there any way of removing them? May be manually?
Both of these task were removed some time ago, they actually don't exist.
Thank you!
Kind regards
Version: TrueNAS-12.0-U2.1 (errors keep from previous versions till now)
You could try re-opening them and dismissing them again... they should disappear after a day or so if that's going to work.
bqz
Thx for replying sretalla. But no, they don't disappear in that way..
