Deadringers
- Nov 28, 2016
Hey all,
So I'm using iSCSI for 2 ESXI hosts to my FreeNAS system.
I'm using 10Gb connections and using iPerf I can get 9.89 Gb between my freenas host and the ESXI systems.
Due to iSCSI being used, sync=always is the only way to ensure writes are immediately written to disk, so I forced sync=disabled as none of this data is mission critical and our UPS is pretty good.
So, with the above information and 128GB of ram I'd expect to see some pretty decent read/write speeds when doing an artificial tests like Crystal disk mark.
However I don't get anything amazing.
Here are results from a couple days ago after a reboot on the FreeNas system:
And here are some results from today after being online for a few days doing "normal VM".
Seq Q32T1 result for writes is basically maxing out the 10Gb link.
The Seq result for writes is also doing fairly well.
But the others are not great for something that I'd expect to be kept in RAM.
This is pretty powerful server which should be caching all writes before writing.
Am I crazy in thinking that at a minimum the Write rates should be higher?
If you have any other tests etc I'm happy to perform them.
