[Not recommended] Latte Panda (redux)
Tsaukpaetra
Since there are now more versions of Latte Panda, I'm starting a new thread from the tails of This thread.
I have received my Latte Panda Delta and for funzies smushed FreeNAS 11.2rc2 on a thumb drive and booted it just fine. I had to add a loader.conf entry to stop it hanging while looking for an SD card in the micro SD slot:
hint.sdhci_pci.1.disabled=1
(add in tunables as a loader config)
Observations:
  • At the 8GB minimum, you are quite limited in what you can do. Don't expect magic here! (duh)
  • You're limited to USB 3.0-connected drives or if you have a M.2 adapter to expose the PCI-e part of the M.2 slot you could in theory plug in a RAID card to add drives. But (If memory serves) this is only a x4 slot equivalent, so again, don't expect miracles.
  • The CPU is reported as 1.0 GHz instead of 2.6 GHz, I'm assuming that's the base clock? It certainly feels like it ramps up to the full speed.
  • VMs (bhyve) do work! But again, you're not going to get any miracles. Do NOT attempt to exceed perhaps 6 GB of RAM (not even with overprovision) Bad things happen very quickly.
  • If you do decide to actually use this legitimately, I would recommend using ARC2. That's probably the only way you'll get anything close to bearable with this.
Overall, it's definitely possible, but why waste your money?
kdragon75
Do you mean L2ARC? As long as everything is using large (128k) blocks/records and you keep the size reasonable (less than 64GB) with a fast NVMe drive and lots of tuning, I could see that being "workable". Haha that means a USB zpool... Never mind!
I have been tempted to get one of these to run ESXi but couldn't justify the price/performance, even at 12 watts or whatever it is.
Tsaukpaetra
Yes L2ARC, it's been a while since I used the proper term.
Yeah, so far the USB pool has only failed to mount twice!
For now I'm using it as a stop-gap for a smoother transition to FreeNAS 11 (migration is stalled because there's no easy way to convert VirtualBox VMs to bhyve.)
kdragon75
You should be able to convert from the V-Box disk to a raw and then dd to a zvol. You may need to do this on linux though as I dont think FreeBSD has qemu tools.
EDIT: Hmm you would still need to convert to uefi boot if the VMs are not already..
