dharmaStatus
- Jul 24, 2011
RESOLVED: Not Acheiving gigabit speeds
Hey all, I have installed freenas and played around with it for a little bit but i seem to be having some issues with speed. My file transfers seem to be maxed around 12 MBps (so ~100mbits /sec), on a fully gigabit network (cat 5e cables, gigabit switch, and gigabit computer) and i tested all of the components individually and manually, so its definitely the freenas thats not achieving gigabit.
I'm not sure if this is a hardware limitation of the processor or ram, or if its a driver issue.
I am running an ion board with the 1.6 ghz atom chip, 2 gigs ddr2 800, and freenas is booted off a usb flash drive. The mobo does support gigabit, for reference its a zotac ionitx-e-e.
I have freenas configured with zfs raid-z on 4 2 TB drives which are WD caviar greens.
Basically my question is if this is a driver issue, or if there is something that i am missing.
Thanks!
FIX
had to change the ifconfig to gigabit, and got an additional 2gb of ram, and ended up acheiving 30 MBps write and ~68MBps read averages
Thanks!
FIX
