Jerzy Sobski
- Mar 6, 2015
I am in process moving drives from a two 10 bay SATA towers using port multipliers which I have been told is very unreliable due to issues when drive goes bad. In process I of preparing to make a switch over to SAS expander I have also begun to look for a way to combine the towers into a single unit.
During my research I have come across the Norco RPC 4224 4U as being one of the most economical storage cases on the market.
Has anyone in recent years tried this case and how did you like it? What issues did you find or resolutions you made to improve on it?
In my research I have come across having to replace the fans and having to go with 90 degree SAS cables for the connecting to the backplane board. Not sure if there are any other issues that I should be aware of before I pressure the trigger to purchase this unit.
This is primarily being purchased mainly for drive storage and cable run to server. Any other suggestions on other economical solutions that would be better then the RPC-4224-4U?
