Need some help planning an array
This Array will be used for home based NAS.. pictures, media, video storage. It need to support real-time recording from my SageTV server .. Typically 2 streams at 2GB/hour
Mostly a write once and read many situation.
Main goal in using ZFS is to prevent a single disk fault from taking it all down. The real critical data is backed up elsewhere.
The server is a Gigabyte P35 MB with 8 Gig Ram and runs ESXi 5.0. Freenas is a guest.
I have a mixed bag of disk... All Segates SATA II
Empty Drives
2x 750G (enterprise class drives ..from a caching appliance )
1x 1000G
1x 2000G
Drives with Data that needs to be kept
1x 1500G
1x 300 (old .. will go to another machine )
What I'd like to do is create an array that has the maximum 'protected' space out of the 1st 4 drives.
- Then migrate the data from the 1500 to the array.
- Then add the 1500 to the array
What is the best way to setup this array in FreeNas
Empty Drives
1x 1000G
1x 2000G
1x 1500G
