Noob haveing trouble with volume degraded
I hope for 2 things
1 - I dont sound 2 dumb
2 - that i can explain this properly
I re purposed an old pc into a nas. I bought 2 seagate 2tb nas drives and used freenas 9.2.1.2 on usb stick as the os..
Everything installed easily and I set up the volume and share with no problem using ufs mirror.
I used ufs mirror as I only have the 2 drives and 2g ram...
everything seems to be working no problem except -
when I log into the nas gui, I have a critical message, volume degraded.
When I look at volume status it says
volume - degraded
ada1 - active
ada0 - synchronizing...
Im assuming the issue is the mirror, but I just don't have a lot of experience with this stuff to know or tell what the real problem is...
again, everything is working, i can write files to the share no problem...
Hm...just checked and now everything is healthy... is it safe to assume while the drives are synchronizing the volume is considered degraded?
Yatti420
Ok.. First did you do the proper burn-in/testing on the machine & new drives? Please run "smartctl -a -q noserial /dev/ada0" "smartctl -a -q noserial /dev/ada1" and post the output here..
well, the tutorial I followed mentioned nothing of testing or burn in... but here is the results
Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x10bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 100 100 006 Pre-fail Always - 671264 3 Spin_Up_Time 0x0003 096 096 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 19 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 100 253 030 Pre-fail Always - 463797 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 19 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 20 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 189 High_Fly_Writes 0x003a 090 090 000 Old_age Always - 10 190 Airflow_Temperature_Cel 0x0022 071 066 045 Old_age Always - 29 (Min/Max 27/33) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 17 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 19 194 Temperature_Celsius 0x0022 029 040 000 Old_age Always - 29 (0 16 0 0 0) 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute
and
""ell
SCT capabilities: (0x10bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 119 100 006 Pre-fail Always - 203774456 3 Spin_Up_Time 0x0003 096 096 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 19 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 100 253 030 Pre-fail Always - 27340 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 20 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 20 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 071 066 045 Old_age Always - 29 (Min/Max 27/33) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 17 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 19 194 Temperature_Celsius 0x0022 029 040 000 Old_age Always - 29 (0 16 0 0 0) 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. [root@freenas ~]# ^C [root@freenas ~]# ^C [root@freenas ~]#
Yatti420
Please (fix smart) post in code tags.. Can you also add "zpool list" and "zpool status" Thanks
Edit: Please post the hardware you are using aswell.. Everything..
ada0
  1 Raw_Read_Error_Rate    0x000f  100  100  006    Pre-fail  Always      -      1508208
  4 Start_Stop_Count        0x0032  100  100  020    Old_age  Always      -      21
  7 Seek_Error_Rate        0x000f  100  253  030    Pre-fail  Always      -      469661
  9 Power_On_Hours          0x0032  100  100  000    Old_age  Always      -      26
12 Power_Cycle_Count      0x0032  100  100  020    Old_age  Always      -      22
190 Airflow_Temperature_Cel 0x0022  070  066  045    Old_age  Always      -      30 (Min/Max 29/31)
193 Load_Cycle_Count        0x0032  100  100  000    Old_age  Always      -      21
194 Temperature_Celsius    0x0022  030  040  000    Old_age  Always      -      30 (0 16 0 0 0)
No Errors Logged
ada1
  1 Raw_Read_Error_Rate    0x000f  119  100  006    Pre-fail  Always      -      204648632
  7 Seek_Error_Rate        0x000f  100  253  030    Pre-fail  Always      -      33208
190 Airflow_Temperature_Cel 0x0022  070  066  045    Old_age  Always      -      30 (Min/Max 30/31)
No Errors Logged
No pools available... this is a ufs volume...
asus m2n-mx se plus mother brd
AMD Athlon(tm) 64 X2 Dual Core Processor 4600+
2g ram..
