Noticed after applying the U6.1 update, every 5 minutes I'm seeing these messages in my log:
smb4.conf file:
I have a couple of SMB shares setup and they all seem to be working just fine. Based on what I could find regarding the error, if the server role is set to standalone, then you should disable winbindd. However I wasn't sure how to disable winbindd or if that was a legit fix. Anyone else seeing this or have a fix? let me know if additional logs/config info would help.winbindd 1318 - - [2021/11/12 06:31:54.172332, 0] ../../source3/rpc_server/rpc_ncacn_np.c:457(rpcint_dispatch)
winbindd 1318 - - rpcint_dispatch: DCE/RPC fault in call lsarpc:32 - DCERPC_NCA_S_OP_RNG_ERROR
smb4.conf file:
[global]
dns proxy = No
aio max threads = 2
max log size = 5120
load printers = No
printing = bsd
disable spoolss = Yes
dos filemode = Yes
kernel change notify = No
directory name cache size = 0
unix charset = UTF-8
log level = 0 auth_json_audit:3@/var/log/samba4/auth_audit.log
obey pam restrictions = False
enable web service discovery = True
username map = /usr/local/etc/smbusername.map
username map cache time = 60
logging = syslog@0 file
server min protocol = NT1
map to guest = Bad User
ntlm auth = Yes
client ntlmv2 auth = No
fruit:nfs_aces = No
bind interfaces only = Yes
netbios name = freenas
netbios aliases =
server role = standalone
workgroup = WORKGROUP
