no such pool(stripe) / physical shock hdd(dropped)
HaNue
I'm trying to replace one hard disk because it's broken, but 'no such pool' comes out.
The configuration consists of stripe, and the specifications are
ryzen zen3 5600g / rog strix b550-xe / samsung ddr4-3200(32gx4) / samsung 870evo / WD HC550(18TB x 16)
This is LSI 9201-16i / LSI 9300-8i.
The reason I posted it to the core is because of the core user, but the pool can only be seen on the scale.
A striped pool means that all data is lost when any device fails--so if your pool in fact consists of 16 disks, all striped together, and one of those disks has completely failed, your data is gone--all of it. But your post is kind of short on details--what's the output of zpool status and zpool import?
HaNue
I'm sorry I don't have a picture.
zpool status displays only the boot pool.
If you import zpool, you will see no very pool.
I didn't ask for a picture; copy and paste the text. If you don't have it, try it again and post the output.
HaNue
I'm sorry for the late reply.
root@Newforms[~]# zpool import
pool: Siyon
state: UNAVAIL
status: One or more devices are missing from the system.
action: The pool cannot be imported. Attach the missing
devices and try again.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-3C
Siyon UNAVAIL insufficient replicas
gptid/31001ad8-9240-11ed-9ce7-50ebf624d1f7 ONLINE
gptid/314c4ff0-9240-11ed-9ce7-50ebf624d1f7 ONLINE
gptid/30f6e24c-9240-11ed-9ce7-50ebf624d1f7 ONLINE
gptid/31119483-9240-11ed-9ce7-50ebf624d1f7 ONLINE
gptid/3108f88a-9240-11ed-9ce7-50ebf624d1f7 ONLINE
gptid/30fc28b4-9240-11ed-9ce7-50ebf624d1f7 ONLINE
gptid/30f9a655-9240-11ed-9ce7-50ebf624d1f7 ONLINE
gptid/30f46e79-9240-11ed-9ce7-50ebf624d1f7 ONLINE
gptid/30c47283-9240-11ed-9ce7-50ebf624d1f7 ONLINE
gptid/3102e403-9240-11ed-9ce7-50ebf624d1f7 ONLINE
gptid/3104e256-9240-11ed-9ce7-50ebf624d1f7 ONLINE
gptid/314e9e8f-9240-11ed-9ce7-50ebf624d1f7 ONLINE
gptid/310d93cb-9240-11ed-9ce7-50ebf624d1f7 ONLINE
gptid/1110b58a-9646-11ed-9bb0-50ebf624d1f7 ONLINE
gptid/111f5d79-9646-11ed-9bb0-50ebf624d1f7 UNAVAIL cannot open
gptid/111e1860-9646-11ed-9bb0-50ebf624d1f7 ONLINE
root@Newforms[~]# zpool status
pool: boot-pool
state: ONLINE
scan: resilvered 11.3M in 00:00:00 with 0 errors on Fri Mar 3 14:50:30 2023
NAME STATE READ WRITE CKSUM
boot-pool ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
ada4p3 ONLINE 0 0 0
errors: No known data errors
So it is as you described it, a single striped pool. If you can't bring this disk back online, your pool is toast.
HaNue
No. As I said above,
Remove one of the mirrored boot ssd.
When I connected the hdd with that connector, it came out like this on the scale and the core. Do you think there's a chance?
Scale
pool: Siyon
state: UNAVAIL
status: The pool was last accessed by another system.
action: The pool cannot be imported due to damaged devices or data.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-EY
sdk2 ONLINE
sdj2 ONLINE
sdn2 ONLINE
sdl2 ONLINE
sdg2 ONLINE
sdc2 ONLINE
sde2 ONLINE
sdf2 ONLINE
sdo2 ONLINE
sdr2 ONLINE
sdp2 ONLINE
sdh2 ONLINE
sda2 ONLINE
sdb2 ONLINE
sdd2 ONLINE
Core
pool: Siyon
state: UNAVAIL
What part of "If you can't bring this disk back online, your pool is toast" are you not understanding?
