I have some problem with my truenas and I'm a newbie to it so I might have configured it badly.
The problem is wether I tried to mount the share from another unix/linux host on the network or windows machine, it doesn't work.
from a ubuntu host that the result from part of smbclient and the mounting command:
And from the VM generated by truenas itself I don't even get an answer....
So What's the right command to mount it? Is there a specfic thing about the name on truenas share that I should know about?
Got pdu len 232, data_len 208
rpc_api_pipe: got frag len of 232 at offset 0: NT_STATUS_OK
rpc_api_pipe: host 172.20.0.83 returned 208 bytes.
srvsvc_NetShareEnumAll: struct srvsvc_NetShareEnumAll
out: struct srvsvc_NetShareEnumAll
info_ctr : *
info_ctr: struct srvsvc_NetShareInfoCtr
level : 0x00000001 (1)
ctr : union srvsvc_NetShareCtr(case 1)
ctr1 : *
ctr1: struct srvsvc_NetShareCtr1
count : 0x00000002 (2)
array : *
array: ARRAY(2)
array: struct srvsvc_NetShareInfo1
type : STYPE_IPC_HIDDEN (0x80000003)
comment : *
comment : 'IPC Service (TrueNAS Server)'
type : STYPE_DISKTREE (0x0)
comment : *
comment : ''
totalentries : *
totalentries : 0x00000002 (2)
resume_handle : *
resume_handle : 0x00000000 (0)
result : WERR_OK
IPC$ IPC IPC Service (TrueNAS Server)
transfert Disk
SMB1 disabled -- no workgroup available
testing@ubu-game:~$ sudo mount.cifs //172.20.0.83/transfert /media/transfert
Password for root@//172.20.0.83/transfert: ********
mount error(2): No such file or directory
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)And from the VM generated by truenas itself I don't even get an answer....
