No nvme drives on Dell R7515
nick17bo
I installed FreeNAS-11.3-U4.1 on a Dell R7515 server with an AMD 7542 CPU.
The system is working fine but no NVMe drives can be found.
I have installed Ubuntu Server 20.04. The NVMe drives are all recognized and work properly.
Does anyone have any idea what I could try?
nick17bo
I installed the NVMe drives on a Dell R640 with FreeNAS-11.2-U6. The drive work properly.
Samuel Tai
According to the R7515 manual, p. 20, only the following NVMe devices are supported:
The following table shows the supported NVMe SSDs for the PowerEdge R7515:
Table 9. Supported NVMe SSD
  Description
  SSDR,1.6,NVMEPCIE,2.5,PM1725B
  SSDR,6.4,NVMEPCIE,2.5,PM1725B
  CRD,CTL,NVME,1.6,HHHL,PM1725B
  SSDR,3.2,NVMEPCIE,2.5,PM1725B
  SSDR,12.8,NVMEPCIE,2.5,PM1725B
  CRD,CTL,NVME,3.2,HHHL,PM1725B
  CRD,CTL,NVME,6.4,HHHL,PM1725B
  SSDR,960GB,NVMEPCIE,2.5,CD5
  SSDR,3.84TB,NVMEPCIE,2.5,CD5
  SSDR,1.92TB,NVMEPCIE,2.5,CD5
  SSDR,7.68TB,NVMEPCIE,2.5,CD5
  SSDR,1TB,NVME,PCIE,2.5,P4510
  SSDR,2TB,NVME,PCIE,2.5,P4510
  SSDR,4TB,NVME,PCIE,2.5,P4510
  SSDR,8TB,NVME,PCIE,2.5,P4510
  SSDR,1.6TB,NVME,PCIE,2.5,P4610
  SSDR,3.2TB,NVME,PCIE,2.5,P4610
  SSDR,6.4TB,NVME,PCIE,2.5,P4610
  SSDR,375GB,NVME,PCIE,2.5,P4800
  SSDR,750GB,NVME,PCIE,2.5,P4800
  CRD,CTL,PCIE,750GB,HHHL,P4800
Welcome to the wonderful world of vendor lock-in!
nick17bo
The R7515 works with my NVMe Micron 9300 on Ubuntu 20.04 fine, so I think there is no hardware problem ....
Alecmascot
The R7515 works with my NVMe Micron 9300 on Ubuntu 20.04 fin, so I think there is so hardware problem ....
Install FreeBSD and see what happens.
nick17bo
With FreeBSD 12.1 same result, no NVMe Drives
nvmecontrol devlist -> No NVMe controllers found
Missing driver???
nick17bo
I installed Ubuntu again and ran lshw to list the device dependency. Here is the output:
Does somebody has any idea?
  • lshw.txt
nick17bo
The kernel module megaraid_sas looks interesting
Hardware -> PCI
Numeric ID (from LKDDb) and names (from pci.ids) of recognized devices:
  • vendor: 1028 ("Dell"), device: 000e ("PowerEdge Expandable RAID controller 4/Di"), subvendor: 1028, subdevice: 0123
  • vendor: 1028 ("Dell"), device: 000f ("PowerEdge Expandable RAID controller 4/Di"), subvendor: 1028, subdevice: 014a ("PowerEdge 1750")
  • vendor: 1028 ("Dell"), device: 0013 ("PowerEdge Expandable RAID controller 4"), subvendor: 1028, subdevice: 016c ("PowerEdge Expandable RAID Controller 4e/Si")
  • vendor: 1028 ("Dell"), device: 0013 ("PowerEdge Expandable RAID controller 4"), subvendor: 1028, subdevice: 016d ("PowerEdge Expandable RAID Controller 4e/Di")
  • vendor: 1028 ("Dell"), device: 0013 ("PowerEdge Expandable RAID controller 4"), subvendor: 1028, subdevice: 016e ("PowerEdge Expandable RAID Controller 4e/Di")
  • vendor: 1028 ("Dell"), device: 0013 ("PowerEdge Expandable RAID controller 4"), subvendor: 1028, subdevice: 016f ("PowerEdge Expandable RAID Controller 4e/Di")
  • vendor: 1028 ("Dell"), device: 0013 ("PowerEdge Expandable RAID controller 4"), subvendor: 1028, subdevice: 0170 ("PowerEdge Expandable RAID Controller 4e/Di")
  • vendor: 1028 ("Dell"), device: 0015 ("PowerEdge Expandable RAID controller 5")
nick17bo
It really doesn't seem to work on FreeBSD. I installed Ubuntu again. Everything is recognized. Then I'll have to stick with it. What a shame
mav@
@nick17bo There are some reports about issues in hot-plug support on AMD EPYCs. Try to set loader tunable hw.pci.enable_pcie_hp to 0. If it help, then it should be fixed in 12.0-RC1 in September.
mav@
What exactly didn't work? Have you set the mentioned tunable? Have you tried recent nightly builds?
nick17bo
Hey Mav,
thank you very much for your support. The system is a productive system and so unfortunately I cannot try the mentioned tunable at the moment (Ubuntu is currently running).
I've tested it with TrueNAS-12.0-MASTER-202006220424 and TrueNAS-12.1-MASTER-202007280438, as well as FreeBSD-12.1-RELEASE-amd64. Unfortunately neither version worked.
