brando56894
- Feb 15, 2014
I haven't really messed around with the virtualization in FreeNAS since it's not really useful (yet) for my needs. I decided to give the RancherOS VM a try and I have it all setup, to the point where I actually install the UI, but my network connection stops at my FreeNAS VM (I have it virtualized in ESXi). I'm currently running FreeNAS-11-MASTER-201801090514
Initially I had no network connection at all, because my NIC in RancherOS wasn't assigned an IP, so I assigned one manually, along with a default route for my LAN. Once I did that I was able to ping the FreeNAS IP and vice versa, but I can't go beyond FreeNAS.
What's the issue?
[rancher@rancher ~]$ ip a 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000 link/ether 00:a0:98:48:1a:03 brd ff:ff:ff:ff:ff:ff inet 192.168.1.5/24 scope global eth0 valid_lft forever preferred_lft forever inet6 fe80::2a0:98ff:fe48:1a03/64 scope link valid_lft forever preferred_lft forever 3: docker-sys: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000 link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff inet 172.18.42.2/16 brd 172.18.255.255 scope global docker-sys valid_lft forever preferred_lft forever inet6 fe80::90d5:d9ff:fe6f:369f/64 scope link valid_lft forever preferred_lft forever 5: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default link/ether 02:42:b0:e8:18:e7 brd ff:ff:ff:ff:ff:ff inet 172.17.0.1/16 scope global docker0 valid_lft forever preferred_lft forever [rancher@rancher ~]$ ip route show default via 192.168.1.1 dev eth0 172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.1 linkdown 172.18.0.0/16 dev docker-sys proto kernel scope link src 172.18.42.2 linkdown 192.168.1.0/24 dev eth0 proto kernel scope link src 192.168.1.5 root@freenas:~ # ifconfig em0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=98<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM> ether 00:0c:29:1c:92:a8 hwaddr 00:0c:29:1c:92:a8 inet 192.168.1.6 netmask 0xffffff00 broadcast 192.168.1.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo tap0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=80000<LINKSTATE> ether 00:bd:67:bb:ff:00 hwaddr 00:bd:67:bb:ff:00 nd6 options=1<PERFORMNUD> media: Ethernet autoselect status: active groups: tap Opened by PID 5329 bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:b5:21:16:71:00 nd6 options=1<PERFORMNUD> groups: bridge id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: em0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 3 priority 128 path cost 2000000
What's the issue?
