martin481997
- Jan 12, 2020
Hello I try to get Plex running inside a Jail, but as soon as i setup a jail with vnet it has no connection to the network cant ping my Jail from Freenas and Freenas from the jail also no internet inside the Jail.
ifconfig freenas
ifconfig jail
Allow Raw_sockets is enabled in the Jail. Network is working if I set Interface to bridge0 or igb0.
ifconfig freenas
igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6>
ether a8:5e:45:3d:41:85
hwaddr a8:5e:45:3d:41:85
inet 192.168.212.100 netmask 0xffffff00 broadcast 192.168.212.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
igb1: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
ether a8:5e:45:3d:41:86
hwaddr a8:5e:45:3d:41:86
status: active
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
groups: lo
ether 02:35:3a:c3:0c:00
inet 192.168.212.110 netmask 0xffffff00 broadcast 192.168.212.255
nd6 options=1<PERFORMNUD>
groups: bridge
member: vnet0:33 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 5 priority 128 path cost 2000
member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 20000
vnet0:33: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: test as nic: epair0b
options=8<VLAN_MTU>
ether 0d:cd:44:ae:1b:75
hwaddr 02:7e:d0:00:05:0a
status: active
groups: epairifconfig jail
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
groups: lo
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 0d:cd:44:ae:1b:76
hwaddr 02:7e:d0:00:06:0b
inet 192.168.212.111 netmask 0xffffff00 broadcast 192.168.212.255
status: active
groups: epairAllow Raw_sockets is enabled in the Jail. Network is working if I set Interface to bridge0 or igb0.
