No longer receive scrub notification emails etc
NASr710
I used to receive scrub notifications emails from my NAS box, but for some reason, it just stopped. I went in to the email settings and test emails are being sent out without a problem. Anyone have any idea?
thanks.
What version of the OS are you on? What's changed?
NASr710
I am on :
FreeNAS-11.3-STABLE - Release Train for FreeNAS 11.3 [release]
Planning on upgrading to TrueNAS, but have not gotten around to it yet.
Nothing changed that I am aware, or remember.
Is it possible that these messages are getting marked as spam and ending up blocked or in your junk folder?
NASr710
No, I checked junk. Nothing. I also checked filters in case I had created one and forgotten, but nothing there either.
Last time I received a notification from FreeNAS was March 21st of this year.
Same issue here. Fresh install of TrueNAS-12.0-U4.1
Email test button works (tried sending to multiple email addresses)
Scrub and Cloudsync tasks are running and completing but no Emails at all.
SYSTEM --> ALERT SERVICES --> EMAIL --> LEVEL = INFO
I just wanted to see how many Emails it would send me at info level. This is correct right, INFO level should mean I get all levels above?
Actually not sure if a cloudsync task is suppsosed to send a start/end message, I only see Cloud Sync Task Failed as an option under Alert Settings.
gawkla
Hello All.
I am on 11.3-U5
I meet the same issue: notification about 'scrub started' is sended out. But for 'scrub finished' - no email.
Anybody have idea how to fix it? Probably it is a bug, maybe some manual correction can be made on internal scripts, but where?
