Now, if you're done with your tantrum, stop and think about this for a few minutes. You suspected that your issue was one of hardware compatibility. You posted asking if this was the case. Didn't it enter into your head for a moment that it might be somewhat relevant to actually list your hardware? Particularly since gpsguy already suggested that in the other thread you posted to? Sure, I (or he, or anyone else) can say "yep, incompatible NIC is likely", but your question wasn't what the likely cause was. To know if an incompatible NIC was the cause of your not getting an IP address, we need to know if the NIC is compatible, and for that, we need to know what the NIC is, and what version of FreeNAS you're using. How could you expect to get a useful answer without that information?
The purpose of the rules is not to enforce arbitrary hoops that users must jump through before they can receive help (it's not like you're being asked to do the Hokey Pokey and turn yourself around, after all, or to sacrifice a goat to your server); it's to save everyone's time (including yours) and get the most accurate answers possible, as quickly as possible. If you figure that you're special and shouldn't have to read or follow them, I guess that's up to you--but you'll be greatly reducing your chances of getting timely, accurate answers.
