No Drive Temps Shown on Dashboard 11.3?
AVSION
Hi Everyone,
I just upgrade from 11.2 U7 to 11.3 U2.1, I can't figure out how to see my HDD temps through FreeNAS on the Dashboard. The new dashboard doesn't show the single disks. Anybody know how I can see the temps? as well is there a way to customise the dashboard widgets to show other reports?
Thank you
Redcoat
1.
Click object in top right corner to get to Disk Reports
2. Select Disk in the first column,
, all in the Devices column and Temperature in the Metrics column.
AVSION
Thanks @Redcoat FN 11.2 had a Disk widget on the dashboard with a icon show all dev disk. to see the temp you only had to click on the icon, see image. as well as had the option to go to the reports as you described. V11.3 it looks like it was removed from the dashboard. can this be added or it was removed?
Redcoat
Yes, I recall that presentation. If it's possible to get it in 11.3 I don't know how.
dak180
Top Bottom
